05-27-2013, 02:27 PM | #1 |
will these exhaust manifold work?
1967 burb 1990 r3500 crewcab |
05-27-2013, 03:07 PM | #2 |
What?
Re: will these exhaust manifold work?
Is your burb a 4x4?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
05-27-2013, 04:22 PM | #3 |
its 2wd
05-27-2013, 06:30 PM | #4 |
What?
That manifold you are looking at is for a 4x4.
05-27-2013, 06:54 PM | #5 |
The application listed is 62-65 corvette. But will they work on 2 WD Burb?
05-28-2013, 07:25 PM | #6 |
They work on my 1960. It's close over the axle with 2.5 tube
05-28-2013, 11:26 PM | #7 | |
Still plays with trucks
I will have my engine back together and in my 2wd stepside in the next couple days. I will fit up the straight down manifolds from my K10 and let you know if they will clear the engine crossmember.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
05-29-2013, 12:28 PM | #8 |
Here's the ones listed for 2-WD pickups and burbs:
http://www.summitracing.com/parts/rn...rban/year/1969 The outlet angles towards the rear. Bob |
05-30-2013, 02:26 AM | #9 | |
I have a set designed for a 68-72 Chevelle on mine. They fit perfectly and tuck up higher than the truck specific ones do so they are not the lowest part on the truck. The front crossmember will hit first. Only down side with Chevelle headers is that the collector exit is right in the middle of the stock truck transmission crossmember. I built a square tube crossmember with maximum clearance to solve this.
06-02-2013, 09:26 PM | #10 |
thank for the help i ordered the dormain manifold off ebay $43.20 shipped to my house.
674-199 is rh side 674-201 lh if anyone needs partnumbers to order any. 68 TT that cross member you bilt is very nice would love to do something like that in the future but for know im just trying to get my burb on the road to see how its gonna run out ive never got to drive it.
08-17-2015, 10:42 AM | #11 | |
http://www.ebay.com/itm/DORMAN-674-2...60502a&vxp=mtr |
