Old 05-27-2013, 04:12 PM   #1
Liddy71
Liddy71's Avatar
going to order some wheels
ok guys I am going to order wheels for my blazer 18s what want its lower 5 front and flip in the rear what back backing do I need want to run a 295-45-18 back front 255-45-18 front or do you all suggest something else.here a pic . In the pic the front has come down more and back up a little. the wheels are on my crew cab build now anyone have pics of 18 on there blazer or truck
Liddy71 is offline   Reply With Quote
Old 05-27-2013, 04:21 PM   #2
77ChevySharkBite
77ChevySharkBite's Avatar
Re: going to order some wheels
Do you have an angle shot you could post? because from the side the tires look fine I like it, I know on the c10 most guys are running 245 or 255 up front and 275 in the rear
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 05-31-2013, 05:30 PM   #3
Liddy71
Liddy71's Avatar
anyone running 18s if could post a pics and size and back spacing
Old 05-31-2013, 07:00 PM   #4
mgchevyparts
mgchevyparts's Avatar
I just bought Riddler 695 gray, 18x9.5 and 18x8 for my 75 Jimmy
The 9.5 come with 5.5" BS, the 8 comes with 4.5" BS
The fronts are perfect as is, the rears fit but could be moved out 1/4" to place in center of tub.
I will probably run them as is since there is clearance. The tires are 295/45/18 and 255/50/18. The rear tire is about 1/4" or so taller then the fronts. If you go with 255/45/18 they'll be about 1" shorter then the rears. I am also doing a rear flip and a 2.5" spindle with 1 cut coil in front, which should be 5"/5"
The rear 295's with 5.5" BS have 1.25" clearance on the inside of the tub and 1.75" clearance from the outer lip
I haven't done the drop yet so any pics I would have right now will be stock height.
I'll add that they fit easily and no matter your drop they clear, front and rear with that BS.
I originally planned on running 18x8's all around but when I put the 255 on the rear it looked too wimpy, so I bought some 18x9.5 to fill it up.
I got a great deal on Ebay, it cost me $577 for the 8's and 9.5's but I had to buy four of each so now I have an extra set of these. I do have a 71 stepside but I'm not certain I want two trucks with the same wheels.
mgchevyparts is offline   Reply With Quote
Old 06-01-2013, 05:54 AM   #5
Liddy71
Liddy71's Avatar
you have any pics of them installed
Old 06-01-2013, 05:06 PM   #6
mgchevyparts
I don't think pics at this point will help any since it's still stock height, top of the wheel opening is about 5" above the top of the tires. I was more concerned that you knew the BS worked well front and back. If you really want I can take some pics.
I dislike having front and rear tires that aren't matching, Toyo proxis STII has all 3 of those sizes in same tire, 295/45/18, 255/50/18 and 255/45/18. The 255/45/18 might be a better choice for the front since Blazers/Jimmys don't seem to have the rake that a pick up has, at least mine seems to be absolutely level all around (stock) where as a pu seems to be slightly lower in front in stock trim. I wont know for sure until I drop it all around.
Old 06-01-2013, 06:47 PM   #7
Liddy71
Liddy71's Avatar
think I will go with the same up only chrome
