Old 05-27-2013, 06:18 PM   #1
Pbaumann
383 rod bolts
I'm trying to get some rod bolts that will fit in the 6in eagle rod and clear the block with minimum grinding. I've ordered the arp striker kit bolts but they will not work in the rod. Any help is appreciated
Pbaumann is offline   Reply With Quote
Old 05-27-2013, 06:40 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: 383 rod bolts
As much as myself and everyone on this board loves to help. Your question is best suited for the manufacture of the rod bolts (ARP) and the rod manufacture (eagle) to help you with your issue.
Are you using a stock GM block or something different? 400 crank with 350 block? Leave it to the experts to help you. It is a lot of money and time to take best educated guesses.
TBONE1964 is offline   Reply With Quote
Old 05-27-2013, 06:42 PM   #3
Pbaumann
Re: 383 rod bolts
Yea it's a 400 crack and the original 350 block. I called arp and the bolts they sent don't work
Old 05-27-2013, 06:46 PM   #4
Lee H
Lee H's Avatar
Re: 383 rod bolts
You will more than likely have to clearance the block with any combo, especially if your mixing and matching parts. This will require you to assembly and disassembly the block several times in order to mark, clearance, and verify. There's no short cuts here. In addition to the block, you'll have to make sure the cam has the proper amount of clearance between it and the rotating assembly. Posted via Mobile Device
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-27-2013, 06:51 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
Re: 383 rod bolts
What did ARP tell you. I understand that the bolts wont work in the eagle 6 inch rods. Do they have a rod bolt that will work> This combination has been done for thousands of years (well since the 400 was invented anyway) It is not an uncommon combination and you should be able to solve this using tech support from one of the suppliers.
Give Eagle a call and tell them what you have going on
Old 05-27-2013, 06:52 PM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
Re: 383 rod bolts
Old 05-27-2013, 06:55 PM   #7
Pbaumann
Re: 383 rod bolts
I know I'll have to clearance the block but the way it is now the block would be cut and probably go into a water jacket. So I'm trying to find another way to do it with out grinding the bolt head. I tried to all arp today but they were closed by the time I called.
Old 05-27-2013, 07:34 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 383 rod bolts
When you bought the rods did you specify for a stroker?There are lots of choices for rod/bolt combos and not all are small enough to use in a stroker.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-27-2013, 09:26 PM   #9
Pbaumann
Re: 383 rod bolts
Yes I ordered them from the machine shop that bored it
Old 05-27-2013, 09:28 PM   #10
Lee H
Lee H's Avatar
Re: 383 rod bolts
I'd be talking to them, wonder why they did not spec rod bolts?
Old 05-27-2013, 09:30 PM   #11
Pbaumann
Re: 383 rod bolts
The rods came with the bolts
Old 05-27-2013, 09:42 PM   #12
Lee H
Lee H's Avatar
Re: 383 rod bolts
Typo
Old 05-27-2013, 09:45 PM   #13
haysonj
haysonj's Avatar
Re: 383 rod bolts
Dont know if they will work with your rods but the bolts on a 6.2 marine engine are already machined for clearance
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 05-29-2013, 05:01 PM   #14
Pbaumann
Re: 383 rod bolts
Had another question. How much can you cut into the block before its to much?
Old 05-29-2013, 05:19 PM   #15
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 383 rod bolts
Depends on where your're cutting.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-29-2013, 05:30 PM   #16
haysonj
haysonj's Avatar
Re: 383 rod bolts
You can't just start grinding on the block. The machine shop should have tools and gages to clearancee the block. I looked at mine and there are spots where they took almost 3/8 of a inch. I would look for a shop that knows what they are doing.
Old 05-29-2013, 07:37 PM   #17
Pbaumann
Re: 383 rod bolts
It's in a shop. I'm just wondering for my own knowledge. Cause they were talkin about cutting 5/16 into the block on the inside like the top side of the crank area.
Old 05-29-2013, 07:46 PM   #18
haysonj
haysonj's Avatar
Re: 383 rod bolts
They cut mine there and also along the panrail, I don't think the water jackets come all the way down the cylinders
Old 05-29-2013, 07:51 PM   #19
Pbaumann
Re: 383 rod bolts
Alright good. Thanks for all the help. Hopefully have it runnin in the next couple of weeks
