Old 05-27-2013, 08:04 PM   #1
asolde
asolde's Avatar
Oil
Just wondering what kind of oils you guys are running and why. I am running Valvoline VR1 racing oil 40wt because it has ashless anti-wear additives and ZDDP to provide ultimate wear protection for our old engines. My engine builder told me to run this oil is the main reason.
asolde is offline   Reply With Quote
Old 05-27-2013, 08:21 PM   #2
Fldawg
Fldawg's Avatar
Re: Oil
I run brad penn 10w30 , because it's full of zinc one thing these older engines need
Fldawg is offline   Reply With Quote
Old 05-27-2013, 09:52 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Oil
NAPA 10W-30 because it's available locally, made by Valvoline, and should keep my basically stock rebuilt 350 healthy until I'm pushing up daisies.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-27-2013, 10:14 PM   #4
richards72chevy
richards72chevy's Avatar
Re: Oil
Quaker state defy.Claims to have boosted zinc.I have just an old worn out 350.If I had it rebuilt I would run the vr1 racing oil.
richards72chevy is offline   Reply With Quote
Old 05-27-2013, 10:29 PM   #5
buckskins4ever
buckskins4ever's Avatar
Re: Oil
Castrol GTX Full Synthetic 5w30.......been running it for years on all my vehicles.
buckskins4ever is offline   Reply With Quote
Old 05-28-2013, 01:52 AM   #6
tmc1986
Re: Oil
To be honest, most of the time I just go with the cheap stuff. I don't put much miles on the truck. O'reilys was having a special the other day. 5 qts of chevron 10w30 and a filter for $13.99. Looks like ill be using chevron for the next ten years because I bought ten jugs and ten filters
'67 2wd LWB 350/4speed.
tmc1986 is offline   Reply With Quote
Old 05-28-2013, 02:20 AM   #7
c10monkey
c10monkey's Avatar
Re: Oil
I'm a Kendall fan. Started using it as a teenager when I built my first engine in a 70 Camaro. And I worked for a local parts store then (1988). I try to support the local or smaller guy. Kendall is now part of the Phillips brand but still good.....
1971 Chevrolet C10 Inflation Fighter
1994 C3500 Crew Cab Dually 454
c10monkey is offline   Reply With Quote
Old 05-28-2013, 06:41 AM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: Oil
Plain old Valvoline 10w/30 with a bottle of ZDDP on all of mine.
Never had a problem so if it ain't broke, no sense in fixing it.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-28-2013, 06:58 AM   #9
rsavage
rsavage's Avatar
Re: Oil
Brad Penn in the old stuff. Mobil 1 in new stuff.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 05-28-2013, 09:43 AM   #10
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Oil
Rotella T, or Delo 400, and change your oil often! Listen, If you want to spend $10 per quart for peace of mind, then by all means, purchase the exotics... I drag race an ride an old KZ-1000 as well as my stock motored truck and they both get the same oil (Rotella T) with a pint of this for insurance and peace of mind in knowing the levels of ZDDP are adequate... http://shop.advanceautoparts.com/web...lone_7660002-p
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 05-28-2013, 09:52 AM   #11
Rufton
Re: Oil
Valvoline VR1 mineral 10W-30 on fresh flat tappet build.
Many have over 200,000 miles using any dino oil.
Probably hard to find a bad oil.
I have good confidence in API ratings from any large company.
Rufton is offline   Reply With Quote
Old 05-28-2013, 09:53 AM   #12
Rickey
Rickey's Avatar
Re: Oil
I run Brad Penn
Rickey is offline   Reply With Quote
Old 05-28-2013, 04:56 PM   #13
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: Oil
Kendall all the way.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 05-28-2013, 05:06 PM   #14
hyatt
Re: Oil
I run WOS (whats on sale) any oil that meets specs is fine
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 05-28-2013, 05:10 PM   #15
Bigdav160
Bigdav160's Avatar
Re: Oil
A big +1
And I spent a few years working at the fuel/lubricants research division of a major oil producer. If it meets API specs there's very little difference between them.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-28-2013, 05:36 PM   #16
hyatt
Re: Oil
Originally Posted by Bigdav160 View Post
A big +1
Thanks for that comment I ran a repair shop for 23 years and always had the brand arguments But as you say If API specs are met there is bacicly no difference As for synthetics they are fine but a lot of dinosours gave there life so you could have crude oil
1946 car hauler
1948 surburban
1937 chevy sedan
1967 ss396 chevelle
Old 05-28-2013, 06:14 PM   #17
69GWC
Re: Oil
I run Quacker State most all the time and if I run something different its Rotella.
69GWC is offline   Reply With Quote
Old 05-28-2013, 07:01 PM   #18
Rufton
Re: Oil
I run WHS (what he said)
