instrument lights-HELP!
in my 1964 Chevy pickup ....
When I bought it the oil pressure gauge, ammeter, fuel gauge and water temp gauge all were not working. The speedometer was broken too. But the turn signals and instrument cluster lights worked, as did the dome light switch and headlights and brake lights. I got another gauge cluster, refinished it, and installed it. Now all the guages work. Fuel, oil, ammeter, and water temp. Lubed and reset the speedometer to 00000.0 and it works perfect. Brake, turn signals all work. But the instrument cluster lights dont work at night. All the bulbs are new. I have power (12V) at the fuse box "instrument" fuse on both ends when the light switch is pulled out. I ground the back of the dash to the steering column with an additional jumper cable but it doesnt work still. Any ideas? |
#2 | |
![]() Quote:
HTH, Sam Last edited by luvbowties; 05-31-2013 at 11:48 AM. Reason: spell |
Re: instrument lights-HELP!
Check the headlight switch. All the lights run through it. Is the dimmer set?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
