Old 05-28-2013, 11:04 AM   #1
offlimts502
offlimts502's Avatar
1960 Apache Front suspension Swap
I found a 1960 Chevy Apache for sale and it's what I've been looking for however the front suspension is the factory torsion bars and I want to set the truck up as weekend autocrosser as well as a nice weekend cruiser. So my question is does it matter if it's torsion bars when you swap in a full suspension kit from Hotchkis or the like?
If I do need to swap it over to coil springs first how much is involved or is it just easier to find a 63-66 instead?
Any help would be appreciated on the matter?
offlimts502 is offline   Reply With Quote
Old 05-28-2013, 01:30 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 1960 Apache Front suspension Swap
Can't answer the Hotchkis question, but the following thread might help with how to swap the suspension to the later coil spring design. It's a relatively simple weekend project:
http://67-72chevytrucks.com/vboard/s...d.php?t=366828
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-28-2013, 08:40 PM   #3
64tantruck
64tantruck's Avatar
We just did this conversion on our 61 apache using a 79 2wd front end. Quite simple. Of course were in teh midst of a frame off, so nothing was in the way. Click the link in my signature and scroll down to see pics. Its almost a bolt in. Only one hole has to be drilled.
Glenn
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 05-28-2013, 09:05 PM   #4
offlimts502
Sounds straight forward enough. Thanks for the info.
Old 08-27-2017, 02:50 PM   #5
Apache20CrewCab
Glenn
Hey Glen,
My name is Rory, I have a 1961 Apache 20 and am planning on doing a front end swap and I just so happen to have a '79 front end that I could buy to do the swap.
I was hoping maybe you could answer a question for me? I am not new to cars and trucks as far as the concepts go but I haven't got much wrench time in.
So the '79 is a C10... do you know if it will bolt into the c20 frame?
Thanks,
Rory
Apache20CrewCab is offline   Reply With Quote
Old 08-27-2017, 03:57 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Ask your question.
Many here can help.
My 65 is on a 62 Frame with a Torsion Bar Suspension. I might even be able to answer your question.
66 C20 Service Truck:
Old 08-27-2017, 04:00 PM   #7
LostMy65
LostMy65's Avatar
Thanks,
Rory
Yes, it'll bolt up the same - C10 or C20.
Either one will take drilling some new holes.
Old 08-28-2017, 12:08 AM   #8
Captainfab
60-66 Nut
The frames are the same in that respect between a C10 and C20. However on the '60-'62's there are quite a few holes that must be drilled. Unlike the '63-'70's which require only 1 hole each side to be drilled and one hole each side to elongate. I believe there is a thread here somewhere by member Markeb01 that details all that needs to be done with a '60-'62 crossmember swap. That thread should be easy to find in the 60-66 FAQ section found at the top of the 60-66 main page.
Hey Glen,
Thanks,
Rory
Old 08-28-2017, 05:21 AM   #9
LostMy65
LostMy65's Avatar
Here is Mark's thread :
Old 08-28-2017, 12:24 PM   #10
Apache20CrewCab
Thanks for the link. This build has of Marks has had my attention for some years. His and another, using POR-15 to protect and finish all the suspension components are what originally peaked my interest.
