Old 05-28-2013, 02:58 PM   #1
Chevroom
67 C30 rear drum removal ?
Ok being new to this how does the rear brake drum come off so I can check shoes and replace wheel cyls? Maybe this is basic but new to me...sorry. Does that cap thing with the 6 bolts need to come off? thanks
Chevroom is offline   Reply With Quote
Old 05-28-2013, 03:42 PM   #2
SS Tim
SS Tim's Avatar
Re: 67 C30 rear drum removal ?
Big learning curve ahead of you.
First thing to do is download the service manuals if you don't have them. Then read up on the brake and axle sections.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
You are right in that the axle shaft does need to come out of the housing then the outer axle bearings. This allows the hub/brake drum assembly to be slid off the housing. The parts are heavy and the axle bearing lock nut is torqued to 175 lb-ft. The hub oil seal is easily damaged during servicing too. It would be best to have some help the first time through.
SS Tim is offline   Reply With Quote
Old 05-28-2013, 03:44 PM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
x2, get some help the first time like Tim says.. not that hard once you have seen it done....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-28-2013, 04:35 PM   #4
Chevroom
Thanks guys for the info and picture and link. It will help greatly! Is (are) there any special tools needed?
Old 05-28-2013, 05:00 PM   #5
haysonj
haysonj's Avatar
It takes a special socket to get the lock nuts off and back on. You can get it at most parts stores.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
