05-28-2013, 03:05 PM | #1 |
2WD Bags on rear
I'm gonna do 3" spindles up front and bags with schraders in the rear to get 5" drop.
What size/brand bags is everyone using on their Blazer/Jimmy's? Completely new to bags. Any input helps. -Matt Posted via Mobile Device
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
05-28-2013, 03:12 PM | #2 |
2WD Jimmy
Re: 2WD Bags on rear
ECE Has a great kit that is perfect for your application. That's what I used on mine. Fits perfect, and works perfect.
Posted via Mobile Device |
05-28-2013, 05:59 PM | #3 |
At $750, it seems expensive. If you itemize it, they are charging over $400 for two bags with line and fittings. Doesn't that seem expensive? I definitely think it has exactly all the components I need though.
05-29-2013, 09:08 AM | #4 |
2WD Jimmy
These are Firestone bags. Not cheap, but will last and take hard use.
Posted via Mobile Device Save up if you need to. It will be worth it on that great Blazer you just got. Don't go cheap on that one. Last edited by Tom Vogel; 05-29-2013 at 09:13 AM. |
05-29-2013, 08:45 PM | #5 |
there are less expensive kits from vendors on this site. i believe Nate at porterbuilt my be one
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
05-30-2013, 04:37 PM | #6 | |
Mr.Vogel, thanks again for the talk. You definitely convinced me of the bags for the rear. I may have to call you again here in a few weeks when I get ready to put this stuff together. Posted via Mobile Device
05-31-2013, 10:34 AM | #7 |
Curious how the bags with shrader valves worked out. Mine had bags all four corners. I took out the front ones but kept the rest of the system, compressors, tank, etc. I was thinkin of getting rid of all that and using shraders for the remaining rear bags. Any input appreciated.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
