1959 gmc 450
Hey guys new to the forum but not to trucks about a month ago I picked up a 1959 GMC 450 truck with a 16' dump bed in it if anyone has any spec sheets or information about these trucks that would be greatly appreciated and also the owners father did a complete engine overhaul a couple years back but he passed and the owner didn't know what size engine it is I'm thinking a 292 inline 6 is what's in it but if anyone knowledgeable about these could chime in that would be great
Posted via Mobile Device |
![]() Join Date: Jun 2011
Re: 1959 gmc 450
Got any pictures?.....We like pictures here. The engine if original would most likely be a gmc 270.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
Re: 1959 gmc 450
Ok well apparently I can't upload pics
Re: 1959 gmc 450
Re: 1959 gmc 450
I love it! Nice truck, man. I think a 270 or 302 GMC is what would have came in it originally.
Re: 1959 gmc 450
So how exactly do I go about finding what engine is in it, I want to ditch the oil bath filter and do a decent conical filter with intake tube for a bit more air flow then an hei distributor and since its been converted to 12v some led lights
Re: 1959 gmc 450
This pic is what I have as of right now if that helps
04 F350 charcoal and chrome, 500hp 6.0l powerstroke 04 GMC Yukon 5.3l with some goodies 1977 Chevy k30 lifted on 37s with sbc 400 and 4 speed 1959 GMC 455v with 10.00-20 tires and 16' dump bed |
Re: 1959 gmc 450
Check the first three numbers on the flat area next to the dissy, probably a 302. Chris
Re: 1959 gmc 450
That is a real workhorse you have. Around here a truck like that would probably have hauled grain to the silo or sweet corn to the cannery.
Re: 1959 gmc 450
That's a slick looking truck.
Kim |
Re: 1959 gmc 450
Ok I found some numbers on the driver side of the block it reads like this " GMC 1 232404 B207"
Re: 1959 gmc 450
The numbers you are after are stamped on the flat boss next to the distributer. The first three numbers tell the displacment of the engine. Chris
#13 |
Re: 1959 gmc 450
Here is a site that is into the inline engines. I have found quite a bit of info here
http://www.inliners.org/ Here too http://www.oldgmctrucks.com/ |
#14 |
Re: 1959 gmc 450
That is what I was thinking it would look like. That thing is awsome.....
#15 |
Re: 1959 gmc 450
Ok ill go ahead and check by the distributor tonight and go from there, by the way what are the specs on this truck? Gvw, tranny, rear end and whatnot
#16 |
Re: 1959 gmc 450
There should be a metal tag attached to the inside of the glovebox door. If it's still there It'll tell you the GVW, trans, rear end, and so on. Chris
#17 |
Re: 1959 gmc 450
Ok thanks ill look again tonight I just have to many projects going on right now and keep getting side tracked
#18 |
Re: 1959 gmc 450
that truck is sweet
thanks for posting pics
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#19 |
Re: 1959 gmc 450
I'm not sure if I want to paint it matte black or what my plan is who ever did the body work years ago bondoed up the natural body lines so its gonna needed sanded down I did a rattle can grey paint job pny 77 Chevy flatbed AMD it turned out good
#20 |
Re: 1959 gmc 450
#21 |
Re: 1959 gmc 450
I defiantly like the body style of this truck better than the 47 Chevy 1.5ton I had
#22 | |
Re: 1959 gmc 450
#23 |
Re: 1959 gmc 450
Its not a 292 (or a 250 or 230 for that matter), Valve cover and intake give it away.Definitely a GMC ingine . Very nice truck . We dont find the larger trucks that nice around here. They usually get run to death- then cut up and scrapped.
#24 |
Re: 1959 gmc 450
Nice truck but may not be original engine, B207 is Feburary 20 1957 casting date on the block. It is possible that GM had engines laying around for a year or so but usually the block date is just a month of so earlier than the assembly date. I know my chevelle was purchased in late august and most of the dated parts are from June and July of the same year.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#25 | |
Re: 1959 gmc 450
