Old 05-28-2013, 03:35 PM   #1
1987chevyv10
3.42 rear with 35s
I have an 87 Chevy 4x4, 350 tbi, sm465, with a 3.42 rear and 35s, would that be alright and not hurt anything, or should I save some money and get some new axles? Thanks
1987chevyv10 is offline   Reply With Quote
Old 05-28-2013, 04:57 PM   #2
KevinD85
KevinD85's Avatar
Re: 3.42 rear with 35s
going to need gears.
also if its a 10 bolt be easy on it. I've broken a few of those with just 31's ha.
1986 chevy k10 silverado rust free from oregon 350 crate big cam,headers and 2.5" duals with an x pipe.
2001 subaru 2.5 rs with a full wrx sti swap track car project
1991 Lexus Ls400 rwd drift toy
2012 lexus is350 awd daily driver
KevinD85 is offline   Reply With Quote
Old 05-28-2013, 06:03 PM   #3
Jonboy
Slots go on anything!
Yeah, you are going to absolutely hate that. 3.73's would be a minimum I would run with 35's, and it will be a dog.
Old 05-28-2013, 06:53 PM   #4
ont_guy_38
ont_guy_38's Avatar
He has the low first gear so he could be ok maybe. i ran 35s' with 3:08 gears but never did any wheeling. Was just a strictly highway truck and never had a problem.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 05-28-2013, 07:20 PM   #5
grayharville
^^who I am^^ what I say>
grayharville's Avatar
It'll suck, I wouldn't run it like that for long, unless you like burning up transmissions.
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 05-28-2013, 07:28 PM   #6
JCampbell
Oh, God, yes. Running 35's on my Sub w/ 3.73s and I hate it. Forget about ever pulling a trailer. She'll lay down on you at the first steep grade you hit.
I've got an ad on CL right now trying to trade my near new 35" Duratracs for some 33's.
JCampbell is offline   Reply With Quote
Old 05-28-2013, 08:03 PM   #7
Rubble
He has a manual tranny,so it wont burn up...I ran 3.42s on 35s in 87 K25 with a 6.2 last summer & it worked great.That was with an auto 400 too. Did really good on fuel & if I was wheeling,just threw in low range.My tranny didnt burn up either..The 6.2 died,but that's another story.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 05-28-2013, 08:36 PM   #8
grayharville
I guess I should have read that closer, with the 465 it would honestly probably be fine. That granny low first would actually be use able on the street then
East Tx Squares
Old 05-28-2013, 08:50 PM   #9
Rubble
Ya,I wasn't trying to be a smarta$$ either...The combo in I had in the diesel was pretty good.It wouldn't pull anything,but I didn't set it up for that.Would still be using it,but the 6.2 has a couple a/c holes in the pan now!!
Old 05-28-2013, 08:59 PM   #10
grayharville
Yeah they were real good about losing their lunch. My next truck I'm building I plan on running a TBI 350, 700r4, 35s and 4.10s. Maybe 4.56. Should be a good streetable combo.
East Tx Squares
Old 05-29-2013, 12:46 AM   #11
85sierraclassic
85sierraclassic's Avatar
I'm running 3.42s and 35s with a mild 350 and a sm365 its not bad. could be lower but granny gear is more like first if you are on much of a grade or incline, but takes off in second/ first just fine on level ground. and runs about 2100-2300rpm At 60-65 pulls hills ok but would suck with a trailer. I'm planned on going to 3.73s just to help a little in the lower end, but don't want it running to hard on the top end without an overdrive, was going to go with 4.10s but decided not to unless I put in an overdrive.
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 05-29-2013, 12:57 AM   #12
Rubble
It all depends on what your going to use the truck for.When I had my 6.2 with the 3.42s I was trying to get some fuel mileage from a turbo 400.It had 4.56s in when I got it,then I swapped in the 3.42s,dropped my cruising rpm at 100km/h from 2800 to 2200.l didn't plan on towing with it,have a dodge/cummins for that,so it was just a daily driver.Worked good..
Old 05-30-2013, 12:32 PM   #13
1987chevyv10
Thanks everybody, ill keep it how it is for now, hopefully it should be alright
Old 05-30-2013, 02:30 PM   #14
Rubble
Ya,see what your mileage is with that set-up.You might like it... Let us know how it does.
Old 05-30-2013, 10:45 PM   #15
68Timber
I know the pieces fit
68Timber's Avatar
I once ran 33's with 3.08's and a 350/TH350 for a good 6 years. I'm sure the slush-box tranny helped cover any gear deficit but honestly it ran and performed pretty good. 35's and 3.42's won't be ideal but it should be doable until you can put deeper gears in.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-31-2013, 12:48 AM   #16
Rubble
When I first got my 80 K10 it had 2.73s in it.I run it with 31s for years,454/465/205 worked pretty decent,then put 33s on it.That was almost too tall,switched to 3.42s & it worked good.
Old 05-31-2013, 10:38 PM   #17
77 shorty
77 shorty's Avatar
Im running 36.5's with 3.73's and the truck is very driveable
1977 K10 shortbox Scottsdale 4x4
1988 C30 Crewcab Silverado
1987 K10 longbox Silverado 4x4
1969 GMC 1500 4x2
77 shorty is offline   Reply With Quote
Old 06-01-2013, 03:34 AM   #18
dubds10
Stalker Nate
I'd say with the manual you'll be fine for now. I was running 33's with 3.73 gearing/th350 trans and towed 7-10,000lbs all the time with my '72 blazer and it hauled great. Without a trailer on it hauled ass, but the crate 350 was no slouch either. Better combo than yours, but not a huge difference. We are running 35s with 3.21 gears in the fiancees Jeep...now that's a dog lol If only it had an LS in it
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
