Old 05-28-2013, 10:46 PM   #1
JWheeler331
JWheeler331's Avatar
Original Rear End or......?
I was looking over the FAQ section and seen some good stuff on rear ends but that got me wondering. Just what do I have.
I assume its the original since the truck is still Drum/Drum 6 lugs.
If it is original does anyone know the gearing that would have came in it?
Are they good or should I look for a 12 bolt posi?
Are there any of the later Chevy Rear ends that would mount straight up to what I have that are 6 lug?
If this has been covered and there is a link with a simple answer im sorry. Sometimes I over read or over think things.
I would love to change to rear disk brakes sometime in the near future and would love to just find something that would bolt straight up to my frame.
Part of my Early Classic front disk brake swap parts came in today.
JWheeler331 is offline   Reply With Quote
Old 05-28-2013, 10:54 PM   #2
Greg63
Enjoy your truck
Greg63's Avatar
Re: Original Rear End or......?
That is the stock original rear axle.
It either had 3.73:1 or 4.11:1 ratio.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 05-28-2013, 10:58 PM   #3
JWheeler331
Greg.
Thanks.
Does the rear end have a name or call number? Its on a 1/2 ton short step.
Old 05-28-2013, 11:02 PM   #4
Greg63
Enjoy your truck
Greg63's Avatar
12 bolt truck differential. 1963 - 1972(?)
Greg.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 05-28-2013, 11:34 PM   #5
66Submarine
66Submarine's Avatar
1963-1982. Often quoted as 64-82, though.
66Submarine is offline   Reply With Quote
Old 05-28-2013, 11:41 PM   #6
JWheeler331
That is what can replace the original?
Old 05-28-2013, 11:44 PM   #7
jayoldschool
Moderator
Greg.
I believe 3.73 was the stock ratio, with 4.11 and 3.07 optional.
jayoldschool is offline   Reply With Quote
Old 05-29-2013, 12:00 AM   #8
66Submarine
Not as a direct swap, that was just the run for the 12 bolt truck rear. 65-70 (maybe late 64 too?) is a direct swap with 6 lugs and coil springs. 63-64 had a fabricated panhard bar mount on the axle tube, 71-72 were five lug, and 73 up had leaf springs. The differential carrier itself interchanges with all of them, although early trucks had coarse spline axles. (63 and 64 I think)
Old 05-29-2013, 12:22 AM   #9
WhippinSaw
WhippinSaw's Avatar
There is a stamping on the axle on the other side by the vent and fill plug. Mine was a GM5 which is the 3.73 ratio. I had to clean it before I could find it.
WhippinSaw is offline   Reply With Quote
Old 05-29-2013, 11:23 AM   #10
JWheeler331
Thanks, I will check it out tomorrow when im over there.
