Old 05-29-2013, 07:09 AM   #1
DjS71
Question 3-On-The-Tree; Post adjusment question
So i rebushed the linkage, cleaned up and greased the column, adjusted the bottom bearing. Hurray, I can get into and out off all of the gears.
My question is that it seems too solid.... I'll try and articulate this....
So lets say I'm in N, headed to 1, clutch in, pull shifter back, pull shifter down and then, here's what I'm not sure is odd or not: when i reach the bottom of the easy travel, i have to apply some seemingly excessive extra force to get it to go into gear. Happens in 2 and 3 also. It navigates the channels just fine but really requires some umph to get it into gear.
Could I have adjusted that lower collar too tight? something else? Working as intended?
Its perfectly mobile, but it seems out of sorts to me.
Cheers,
-Dan
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 05-29-2013, 07:15 AM   #2
cdowns
cdowns's Avatar
Re: 3-On-The-Tree; Post adjusment question
have you ever flushed the tranny and put new tranny fluid in the tranny
Old 05-29-2013, 07:35 AM   #3
DjS71
You know what? The thought hadn't crossed my mind, I haven't cracked it open since I've owned it. Given the state of the rest of the truck, I doubt it's been opened up in decades. Drain & fill is in my future (not sure how you 'flush' a standard trans)
Guess I ought to crawl under there and figure out which flavor of 3 speed I have and go from there.
Reckon the rear end will be up next...
Old 05-29-2013, 07:51 AM   #4
cdowns
cdowns's Avatar
b4 draining them i always put in either a can of marvel mystery oil or a quart or so of kerosene// use the truck for very light use about 20 or so miles to allow circulation// them drain and fill with freash tranny grease
Old 05-29-2013, 08:10 AM   #5
Rufton
If no drain plug I siphon lube out w/ 3/8" hose.
When dropping tranny maintain orientation to avoid mixing ground gear bits w/ bearings.
Clean bottom magnet.
I dropped tranny and flushed w/ kerosene then checked bearing play and smoothness.
Blew kerosene out then sun baked.
Lubed bearings.
Used RTV instead of gaskets.
Lubed and sloshed lube around.
Installed new metal shifter bushings.
Rufton is offline   Reply With Quote
Old 05-29-2013, 09:52 AM   #6
68gmsee
Active Member
68gmsee's Avatar
My 68 GMC did the same think after I replace rubber bushings on the link arms -top and bottom. I found shift levers were rubbing against each other and had to loosen them up at the top and rotate slightly so that they wouldn't touch while shifting. Find someone that's familiar with column shifting and have them go through the gears while you obseve the links in engine compartments.
Also, as a test, disconnect linkage at the bottom and manually move the levers through the gears to make sure they engage. And, lastly, check the clutch adjustment.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-29-2013, 10:11 AM   #7
Rufton
68gmsee is right. If maladjusted or over worn the linkage can bind.
To check if tranny is stiff just disconnect linkage and verify shifts are easy.
Old 05-29-2013, 11:00 AM   #8
steelhorse
steelhorse's Avatar
Here is an issue I had with a 55 chevy. The motor and trans mounts had worn and sagging and were binding up the linkage. I replaced the mounts along with the shifter bushings and it shifted better than it had in 15 years.
steelhorse is offline   Reply With Quote
Old 05-29-2013, 11:02 AM   #9
DjS71
I'll check for bind when I wake up (graveyard shift), interesting bit regarding the mounts.
Thanks, gang.
Old 05-29-2013, 11:45 AM   #10
Rufton
Good point. After installing fresh mounts my shifter wouldn't work anymore and I had to adjust.
