Old 05-29-2013, 10:48 AM   #1
yumyumchoppers
trailing arms
what are the pros and cons of welding up the seams in the trailing arms?
yumyumchoppers is offline   Reply With Quote
Old 05-29-2013, 11:48 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: trailing arms
Since you still want some twisting action of the arm, I would not fully weld the seams but stitch it. Here is what I did, top and bottom.
I also reenforced the front bushing area.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-29-2013, 11:49 AM   #3
rideblue00
rideblue00's Avatar
Re: trailing arms
i dont imagine there are any cons. i welded mine up. stich welded it in 5 places on top and same on bottom.
rideblue00 is offline   Reply With Quote
Old 05-29-2013, 01:31 PM   #4
Dreddybear
Dreddybear's Avatar
Re: trailing arms
I suppose it's worth noting that if you just burn in and weld the entire thing in one pass it'll warp.
I was checking out my arms coming up with a plan to bag my truck. I'll likely hit em in a couple places like these guys did.
Dreddybear is offline   Reply With Quote
Old 05-29-2013, 04:11 PM   #5
LVPhotos
LVPhotos's Avatar
Re: trailing arms
I stitched welded the seams used CPP's boxing plates and powdercoated mine.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-29-2013, 04:15 PM   #6
LVPhotos
LVPhotos's Avatar
Re: trailing arms
I just got these from Porterbuilt. 1/2" to 1"+ longer to help center axle in wheel well, 1" drop built in.
Old 05-29-2013, 05:05 PM   #7
Vernski
Re: trailing arms
Very nice but how much $$...Vernski
Vernski is offline   Reply With Quote
Old 05-30-2013, 02:08 AM   #8
RockTonka
RockTonka's Avatar
Re: trailing arms
Stitch welded and dimple die plated ours...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 05-30-2013, 12:13 PM   #9
LVPhotos
LVPhotos's Avatar
Re: trailing arms
I got mine tax and shipped $639, the standard ones are $499 1" or 3" built in. Now there is a "new" '62 pattern I am sure the price will settle.
RockTonka Like the arms. I just did the top and bottom never thought of the sides. Looks like a "pre-runner" desert truck.
Old 05-30-2013, 07:32 PM   #10
yumyumchoppers
Re: trailing arms
wish i had dimple dies. thanks guys for the quick and informative replies
Old 05-31-2013, 06:33 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: trailing arms
Great looking arms all around.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-31-2013, 07:23 PM   #12
cantada
Smile Re: trailing arms
Redid mine a month or so ago... cut out the bad and welded in new 1/8 inch plate on the vertical part of each arm. Drilled out rivets and used 9/16 and 1/2 inch bolts. I don't plan on drag racing, more of the home depot type trips. Not exactly stock but looks very stock to the occasional observer.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=518877
cantada is offline   Reply With Quote
