Old 05-29-2013, 11:08 AM   #1
3li9
3li9's Avatar
402 carburetor?
hi
my dolly runs good. she has a rochester quadrajet on it i cant find out wat size it is.. don t know where it is wright on it.the cfm size... where did it is written on?
my question what is a god carb to fit it? i have 402 bb with a flowmaster exhaust system with custom headers and an edelbrock performer rpm q-jet inlet.
it works great but it is old and needs to be overhauled when she is cold she needs 3 4 turns to start...i think i have to change the setup because in europe we run 95 octane... so i perhaps change it completely... or do you think to let it on and only rebuild it?
here some pics...
maybe anyone knew that thing
Loving my Dolly
Greetings from Germany
Andy
3li9 is offline   Reply With Quote
Old 05-29-2013, 11:23 AM   #2
truckster
truckster's Avatar
Re: 402 carburetor?
The Quadrajet is an excellent carb. Most of the stock Quadrajets will flow in the 750 CFM range. Yours looks like it could use a rebuild. Cliff Ruggles is an excellent source for information and parts:
http://www.cliffshighperformance.com/
truckster is offline   Reply With Quote
Old 05-29-2013, 11:29 AM   #3
MARKDTN
Re: 402 carburetor?
If it works well, I would rebuild the Qjet. A Qjet is a great carb for mileage and power. They get a bad reputation because if not rebuilt correctly, theyt can bog and do other bad things.
If you are dead-set against the Qjet, Holley used to have a carb just for this application-402BB spreadbore 750CFM vacuum secomdaries. I ran one on a 455 Pontiac years ago and it was a good match for it too.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is online now   Reply With Quote
Old 05-29-2013, 11:40 AM   #4
3li9
3li9's Avatar
Re: 402 carburetor?
thx for the reply
i look what a rebuild will cost...
i am not against it is my first v8 and i only drove 250 miles so i couldn t judge it
thx
Loving my Dolly
Andy
Old 05-29-2013, 11:51 AM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: 402 carburetor?
Well, If you reside in germany, you will need to locate a knowledgeable repairmen/shop. If you will rebuild it yourself, then research is the best start to understanding. Good source for parts:
http://www.carburetion.com/
They are not really that difficult to rebuild and set up. Here is another link to assist:
http://www.florida4x4.com/tech/
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 05-29-2013, 12:00 PM   #6
3li9
3li9's Avatar
Re: 402 carburetor?
thx a lot
i will do it my self...
no risk no fun
maybe i buy a second one used and rebuild that so i have one that runs it will cost more but i can drive anyway if i will fail
hihi
Loving my Dolly
Andy
Old 05-29-2013, 12:49 PM   #7
3li9
3li9's Avatar
Re: 402 carburetor?
@ truckster
i just ordered his book and send him a message to get the rebuild kit i need
thx a lot
Loving my Dolly
Andy
Old 05-29-2013, 01:31 PM   #8
truckster
truckster's Avatar
Re: 402 carburetor?
Bitte und viel Glück!
I've spoken with Cliff several times. He's very knowledgeable and a really nice guy.
Old 05-29-2013, 01:51 PM   #9
geezer#99
geezer#99's Avatar
Re: 402 carburetor?
Here's some more links for you.
http://www.carburetor-blog.com/?page_id=335
geezer#99 is online now   Reply With Quote
Old 05-29-2013, 02:31 PM   #10
Coley
Coley's Avatar
Smile Re: 402 carburetor?
I highly recommend you keep the quadrajet and take on the rebuild yourself.
They are good carburetors and they are not above being rebuilt or renewed by someone with reasonable mechanical skills and understanding.
The biggest start point is to see how much 'play' is in the throttle shafts...particularly (and usually) the primary throttle shaft.
Here is a really interesting video on rebuilding one....from teardown to rebuild although he doesn't really discuss the throttle shaft issue.
(just follow the series through 1 by 1...very helpful and interesting and there are a few other good unrelated videos as well)
To be quite honest, if you get a carb kit for it...carefully disassemble it and VERY, VERY thoroughly clean it and re-assemble it....you'll be surprised at how much better it runs.
OR as a lesser start point...remove it from the engine...soak it, clean it heavily with carb cleaner from both ends and then use compressed air to thoroughly blow it out.
Regardless,....keep the quadrajet!!...its a very good carb when its set up properly.
Good luck and Wie Gehts!!
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 05-29-2013, 02:45 PM   #11
3li9
3li9's Avatar
Re: 402 carburetor?
hey thx a lot
i will keep it
start downlad these videos to my tablet now...
thx dude...
es geht gut
Loving my Dolly
Andy
Old 05-29-2013, 04:07 PM   #12
geezer#99
geezer#99's Avatar
Re: 402 carburetor?
While the video's will help you he does install the needle with the small clip on to the float incorrectly. The wire doesn't get hooked thru the hole. The wire gets hooked on from behind like in this link. If you hook it thru the hole the needle is pulled off centre and you'll get a flooding situation.
And this another good link for you.
http://www.crankshaftcoalition.com/w...#Trouble_spots
