Old 05-29-2013, 03:45 PM   #1
Daubs
Daubs's Avatar
Shorten accelerator cable?
72 K-20 (frame from K-20, body from C-20). Edelbrock carb and performer intake.
Gas pedal had good spacing from floor...but after messing with carb this weekend the gas pedal is very close to floor now. Not sure what the heck i did. Truck runs fine.
I see "cable retainer" in LMC catalog. Is there an easy way to shorten my accelerator cable and get that gas pedal away from floorboard?
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 05-29-2013, 03:52 PM   #2
Gene
Gene's Avatar
Re: Shorten accelerator cable?
Did you use the same cable from the C20? 4wd engines set back further than a 2wd truck, therefore the cable will be a different length.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 05-29-2013, 05:16 PM   #3
Daubs
Daubs's Avatar
Not sure. previous owner did the swap. That could be the problem...but the gas pedal was okay a week ago(?)
Cable does have big curve between carb and firewall.
Old 03-05-2015, 01:03 PM   #4
das601
das601's Avatar
Can you update this post to let us know how you fixed it? Same problem but might just need a cable from a 4x4 as the one installed from the PO is too long.
1971 GMC 4x4 4 speed Project
das601 is offline   Reply With Quote
Old 03-05-2015, 01:47 PM   #5
El Dorado Jim
Does anyone know where to get the one for a 4x4?
El Dorado Jim is offline   Reply With Quote
Old 03-05-2015, 01:53 PM   #6
Bigdav160
Bigdav160's Avatar
I got a long one from a junk yard and shortened it. I'm not sure I can adequately describe the process but I did use a drill press to remove the extra sheath material in the retainer block. I used a drill bit the same size as the sheath so I could re-glue the shorted piece back in. I used a fishing line crimp on the pedal side of the shortened cable. It worked great.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-05-2015, 04:48 PM   #7
snipescastle2
snipescastle2's Avatar
Talking Re: Shorten accelerator cable?
did you by chance happen to move or place the cable bracket in a different bolt location? is it a factory bracket or aftermarket bracket? could it be turned around/upside down, that could effectively Lengthen/shorten the cables reach, causing your issue.....
HTH,
Ben
snipescastle2 is offline   Reply With Quote
