05-29-2013, 06:13 PM | #1 |
TPI Surging
I'm running a TPI setup on my truck, noticed that at stop signs or lights the engine surges. It gets so bad at times I have to struggle to keep the brakes depressed to keep it from launching into on coming traffic. Any ideas what's going on?
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
05-30-2013, 07:00 AM | #2 |
Re: TPI Surging
Check for vacuum leaks, spray carb cleaner around manifold and see if idle picks up, stalls, or smooths out. in some rare cases you might only find a leak with a smoke machine. Good luck.
05-30-2013, 08:25 AM | #3 |
Re: TPI Surging
Throttle plate gummed up (not completely closing) ? try cleaning plate and body and arm plate mounts in body.
05-30-2013, 08:36 PM | #4 |
Re: TPI Surging
i'd ask on hotrodders.com
shrek? are we related
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-30-2013, 09:39 PM | #5 |
Re: TPI Surging
I would check the TPS voltage. (Throttle position sensor)
05-31-2013, 06:03 PM | #6 |
Re: TPI Surging
06-01-2013, 11:12 AM | #7 |
Re: TPI Surging
it's not like your not building a f*rd
06-01-2013, 08:16 PM | #8 |
Re: TPI Surging
Adjusted the IAC (TPS), problem solved.
