54 Chevy, with 9 foot bed
I have an opportunity to purchase a 54 Chevy, 3/4 ton, in good condition for $1,000. The truck has a 9 foot bed. I don't want the 9ft bed, what options are there? Can I shorten the frame, and install a short bed?
Thanks, for any ideas. |
Re: 54 Chevy, with 9 foot bed
If its in nice shape and has a title then its worth $1000 easy. You could shorten the frame or just buy a shortbed frame off a guy doing a s10 swap. Or do a s10 swap yourself. I have also seen people cut the bed down from long to short or you can just replace the bed sides and reposition the cross bars. Just a little engineering.
Yes you can shorten the frame. You can also shorten the bedsides
Posted via Mobile Device |
Are the wheel bases the same? It seems longer in the pictures. I haven't seen the truck in person.
I think that one has a 137 inch wheelbase and is rated at one ton. If it had a really nice 9 foot bed I'd be inclined to either sell the bed to someone wanting to redo a truck with that bed or trade it for an equally nice short bed.
The price sounds pretty decent at today's prices for a real solid truck with a clear title.
Which wheel bases? Please clarify your question.
There were 3 beds. Short, long, and longer. You have the longer one. |
The wheel base between the front and rear tires. I have no problem cutting the frame behind the rear tires. I wouldn't cut the frame between the tires.
The wheel bases are longer on the longer bed trucks so you would have to cut the frame down between the wheels.
Everything you need to know about the frame:
http://chevy.oldcarmanualproject.com...esto/54129.htm short bed: http://chevy.oldcarmanualproject.com...esto/54060.htm long bed (90"): http://chevy.oldcarmanualproject.com...esto/54068.htm longer bed (108.25") http://chevy.oldcarmanualproject.com...esto/54076.htm This info came from the site in my signature. when you click the link you land on a 56 frame page, scroll down to the year index link.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Shortening the frame isn't really a big deal if done correctly. However if you do indeed have the 9 foot bed then your truck is a 1 ton. Therefore rear end gear ratios are going to be really really low. Also brake parts for the 1 ton drums are hard to come by. Like others said, you should either buy a 1/2 ton frame or do the S10 frame swap. The cabs and front sheet metal are all the same. Also please don't cut down that 9 foot bed. They are hard to come by. I am in need of one for my truck but sadly you are too far away to come get yours. Some of us crazy guys like the big 1 ton trucks with the long beds.
1952 3800 GMC 2008 Harley VRSCDX 2011 Road King Classic 2012 Sierra Denali 2500HD 1966 Datsun Roadster 1600 1965 Chevelle SS |
Thanks everyone, I decided to pass. I would want to keep the truck as original as possible.
i'd keep the long bed
everyone has a short bed you'd be the only one with a 9 foot bed
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#13 |
![]() ![]() Join Date: Nov 2008
#14 |
Still livin the "dream" in '54
I just bought a 1954 3800 with a 9 foot stock step-side bed for $1500.00.
It is NOT exactly what I wanted BUT, I started thinking that if I scrapped the stock long bed and replaced it with a nice wooden flat bed then I may end up with something different and unique. I decided to keep the 1-ton look with a flat bed. Only having to deal with the cab (as per body and paint work) makes for a quick build. I say go for it. These trucks are getting harder to find, so grab one that most people would pass by and do something that is not like the 90% of the '54 Chevy trucks out there. I cannot imagine a single person not taking a second look at your finished truck driving down the road. ![]() D
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
