05-29-2013, 10:53 PM | #1 |
Need to put a Holley on a qjet intake...
So my son bought a used 305 to put in his '69. It came with a QJet so he put it back on there. It's running a little rough, butterfly doesn't open all the way and could probably use a rebuilding. I happen to have my '86 sittin there waiting to get the heads rebuilt and I have a Holley 600 on it.
Tried to swap them out...yeah, not so much. Who knew that it wouldn't just bolt right on to a stock qjet intake Do they make adapater kits for such a thing? I've looked around and most I could find was something like I have on mine, but the studs don't have a place to screw into to hold the carb down. I have an Edlebrock intake though. Any ideas?
1st - '68 long bed 2nd - '81 SWB Now - '86 SWB, Edelbrock 1406/stock 350/700r4 |
05-29-2013, 11:56 PM | #2 |
Re: Need to put a Holley on a qjet intake...
Im pretty sure they make adpaters, check with http://www.summitracing.com/
Another thing, a 600 cfm carb is borderline too big on a stock 350.. putting it on a 305 is totally over carbing it lol. Also is this what you were talking about? http://www.holley.com/17-6.asp here's a cheaper solution http://www.carburetion.com/products/...px?part=TD2066
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
05-30-2013, 09:04 AM | #3 |
You mean there's such a thing as over carbing
That is something I was looking for, I guess I'm just not sure how it's going to work because when I put the allen head bolts in the manifold, the carb studs just fall out the hole. There has to be some way...don't there?
05-30-2013, 09:17 AM | #4 |
The bottom gasket "holds" the nuts but when i did mine on my 79 same carb n adapter it had a gap at te front of the area where it bolts too about a half inch back 2 inc wide. MAJOR INTAKE LEAJ
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
05-30-2013, 11:36 AM | #5 |
a 600 is over carbing? isn't a Q-jet 795 or something like that?
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project |
05-30-2013, 12:01 PM | #6 |
My '85 350 came factory equipped with a 790 cfm Q-jet.
05-30-2013, 12:47 PM | #7 |
600cfm is fine. Airflow doesn't matter as long as the motor can get what it needs and it gets signal to the booster.
So why not find a square flange intake on Craigslist? It's a worthwhile upgrade. And everything will fit. Just food for thought. But yes there are adapters to put a square bore on a spreadbore flange. Mr gasket and edelbrock make them Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-30-2013, 04:39 PM | #8 | |
I'm using the Edelbrock adapter and it has carb studs threaded into solid aluminum, is wider to prevent vacuum leaks and is made from a solid piece of machined aluminum. The cheaper ones are cast from beer cans in china. I have had no problems with the Edelbrock. Sorry I don't know the part # Posted via Mobile Device
05-30-2013, 11:17 PM | #9 |
He picked one up at AZ. It's the spectre brand. Probably not top of the line but he's running the streets again so he's a happy 18 yr old
I put a vac gauge on there and didn't detect any leaks. It bolted right up and had threads for the studs. Little loc tite and its good to go. I appreciate y'all's inputs. And just for the record, he said that's the first time the tires have spun a little on excelleration. Lol Posted via Mobile Device
05-31-2013, 01:49 AM | #10 | |
05-31-2013, 04:05 PM | #11 | |
05-31-2013, 08:52 PM | #12 | |
The vacuum secondary's on the Q-jet will only open depending on the air requirements of the engine. In my mind, I see the q-jet (and possibly any VS carb) as up to 750cfm (or whatever it's rated for). Basic Q-jet can be found on V-6's up to big blocks without major changes. Holley's I know very little about, I do know double pumpers are a completely different animal. Hopefully someone with superior knowledge can chime in and explain it better.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
05-31-2013, 11:59 PM | #13 |
I'd fix the Q-Jet personally.
<zips up flamesuit> I could honestly never get a typical out of the box 0-1850 600 CFM vacuum secondary Holley to run right and not be pig rich all the time on a mild small block. |
06-01-2013, 12:29 AM | #14 |
Personally, in my limited experience I found Q-jets to be mystery carbs to repair if they don't work right. I think your biggest bang for the buck is an aftermarket manifold designed for a small Holley or possibly better yet a Carter 4bbl rather than screwing with a Q-jet manifold etc. I am sure you will be happier with the results. But yes, I have seen Q-jet adapters sold.
Randy |
06-01-2013, 02:20 AM | #15 | |
Now the question why you would put a big carb on a small motor? No reason othe than to not limit top end power but an oversize carb will kill low end due to less velocity through the Venturi, this velocity means the cylinders fill more and gives you better low end. Technically you can put a dominator on a stock 305 and not use any more fuel than a 500cfm carb. As long as your booster can get signal to the booster so it can meter the fuel curve. There's a lot to read on for carbs and I could prob write you guys two pages of stuff on carbs easy but this gives you the basic idea. As long as you properly size the carb to your purpose you won't be disappointed with how it works Posted via Mobile Device
