Old 05-29-2013, 10:53 PM   #1
72_ChevyMan
Ac question
So im removing all of my ac components. Got under hood removed but can't figure out how to remove under the dash. Can anyone please help me? It throws coolant everywhere in cab at the moment. Thanks in advance for any info or help! Im quite the noob at all of this
72_ChevyMan is offline   Reply With Quote
Old 05-29-2013, 11:11 PM   #2
Roninwolf
Roninwolf's Avatar
Re: Ac question
If you are getting coolant in your cab your heater core is shot.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=531265
72 Cheyenne Super
90 Z71 S.B. 434 C.I. Stroker
78 Camaro Z28 (gave to wife she is restoring it)
Roninwolf is offline   Reply With Quote
Old 05-30-2013, 08:37 AM   #3
72_ChevyMan
Re: Ac question
Im doin away all ac and heat. But cant figure out how to get the component that is under the dash on right side out. That's where im having trouble.
Old 05-30-2013, 03:14 PM   #4
72_ChevyMan
Re: Ac question
Any suggestions at all?
Old 05-30-2013, 04:18 PM   #5
Katrina/10
Katrina/10's Avatar
Re: Ac question
There are bolts on both sides.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 05-30-2013, 05:10 PM   #6
truckster
truckster's Avatar
Re: Ac question
If you remove the fasteners on the engine compartment side of the firewall, you can pull the AC evaporator. You'll have to go from the cab side (way up under the dash) to get the heater core out.
truckster is offline   Reply With Quote
Old 05-30-2013, 05:22 PM   #7
72_ChevyMan
Re: Ac question
I do not have to remove dash to do it do i?
Old 05-30-2013, 05:27 PM   #8
72_ChevyMan
Re: Ac question
I cannot seem to find any of these fasteners. Know of any diagrams anywhere?
Old 05-30-2013, 05:57 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Ac question
There's four bolts that hold the inside to the outside. You have to be able to get to both sides. It was not a problem for me, the engine and transmission were out, the front cap was off....piece of cake.
There are two holes on the bottom side of the evaporator housing. On each side of the housing, there's one that's closer to the top. Look at the picture and you can see the holes. If you click on it, you can make it bigger. If that doesn't work, then save it to your computer and open it and zoom in on it. If I was nice, I'd crop the picture and make it easier, but I'm an old ogre school bus driver meanie kinds of guy. Okay, I cropped it...so, study the holes...
Member Nr. 2770
Old 06-02-2013, 10:37 PM   #10
72_ChevyMan
Re: Ac question
Thank you a ton ChevLoRay. That helped out tremendously. Got it out and capped off. Thanks everyone!
