6cyl number by distributor
guys, I have searched many web sites for decoding the stamped number by the distributor on my 1966 c20 with 6cyl. they all seem to be for v8 engines. the number is f0422tcd. can anyone help? thanks Lowell
Never Ending Projects
Re: 6cyl number by distributor
Here is a good site for these codes. Looking at it, are you sure it's tcd as there are not listed with tcd.
http://www.novaresource.org/codes.htm
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#3 | |
![]() Join Date: May 2009
![]() http://en.wikipedia.org/wiki/Chevrol...ond_generation |
![]() ![]() Join Date: Apr 2012
TCD Suffix shows up as a 1973 307 V8, might want to recheck the numbers ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
TCD comes up 1971 250 with manual trans out of C 10 or C20
I agree with factorystock. The LMC catalog also agrees. 250ci from a 71 or 72 truck.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
Thanks gents, factorystock, where did you come up with 1971 250cid? the number is stamped very clear. you could be correct. I bought this truck from original owners auction. It has always been shedded. It has the usual small farm dents and scratches.I bought it because of the 8ft dump bed with wooden grain sides and stockracks. It is a 66 c20. I'm going to put it to work. Will try to get pictures. Lowell
Great !! glad you could find it. It did not show up in my Chevrolet 1946-1972 light truck parts book so I looked in the 1973 up parts book, that's where it shows up as 1973 307 ? Odd ???
