05-29-2013, 10:57 PM | #1 |
Caster and shackle
Hello All,
This it it, I am fed up with my steering. 89 v2500 350, 400t I installed my new PSC gear box and that part steers great. I have New DREs, TREs, rag joint, ball joints. The truck still has play. Is this just the nature of the beast? Today I even got out my dial indicator and measured in 1000th any play between the gear box and the steering arm. The rotation of the shaft instantly measures on the dial although 10degrees of rotation only measures a few thousand at the pitman arm Here is the question; What is everyone running for caster? The factory setting is 7.5-8.5. I am running 10.5 degrees with a 2 inch tuff country spring. I was at 6.5 so i added the 4 degree shim. Has anyone replaced the shackle to the frame bushing, or upgraded this bushing and noticed any significant improvement? I have not measured any play in the slip joint opposite the rag joint. It feels tight. Has anyone replaced this joint and noticed an improvement? I only went 2 inches of lift for now so i can still fit in the garage. I had plans to regear, go higher and build a motor but i am getting tired of the driveability and can't see wasting more time and $ Any response is greatly appreciated, Chris |
05-30-2013, 12:19 AM | #2 |
Re: Caster and shackle
4wd? A lot of reman steering boxes actually surprisingly are still sloppy that and 4wd will be a lil more sloppy than a 2wd counterpart.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-30-2013, 07:58 AM | #3 |
I think your caster setting is appropriate.
I can't comment on all the other stuff. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-30-2013, 10:59 AM | #4 |
It is a box from PSC. I can turn the wheel back and forth without power assist. I though it was the box but the dial indicator detects movement in an instant although it is small.
05-30-2013, 11:01 AM | #5 | |
Do you know what you are running on yours? should i try adding 2 more degrees? |
05-30-2013, 11:36 AM | #6 |
You could try another 2 degrees but I doubt you would see much difference.
If you are at 10 degrees you are already almost double the production spec. I don't own a 4wd but my experience comes from fixing customer problem vehicles that dealer's couldn't fix. We would crank the caster way up (10 or 12 degrees) in order to help with on center feel and straight line stability. K
05-30-2013, 12:51 PM | #7 | |
05-30-2013, 01:27 PM | #8 | |
I will call PSC again to ask. Chris |
05-31-2013, 08:48 PM | #9 |
You can install a steering shaft from a late 80's early 90's Jeep XJ. It will be tighter because it has u-joints instead of rag joint. It collapes in the middle for safety. It makes a huge difference. I took one out of a junk yard and it helped big time on my old Blazer.
05-31-2013, 11:41 PM | #10 | |
06-01-2013, 02:04 AM | #11 | |
06-02-2013, 06:35 AM | #12 | |
06-26-2013, 04:09 PM | #13 |
Still plays with trucks
Good to know. Thanks for the info.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
