This may not be a good idea, but I got a set of the 73-87 u-bolts coming and an trying to figure out the easiest way to change them. Can I do one at a time with the spring in place or do I have to separate the lower ball joint and remove spring first to change the U-bolts ? Opinions? Thanks.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=518877 |
Re: LCA U-Bolt Replacement
I would remove the spring. They are not something to mess around with considering the amount of tension under load.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
As Jon says, any other way would be suicide.....!
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I would take the spring out personally.
Another way that I wouldnt recommend is to use spring compressor to keep the pring compressed and then change one at a time.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
![]() Join Date: Oct 2012
REmove the spring. I tried it one at a time and with spring pressure and working around the cross shaft, it sucked and was dangerous. Jack stands slip around, the cross shaft gets in the way....things got better and safer once the spring was out and I could drop the entire lower control arm and shaft out of the way.
Rent a coil spring compressor. Compress the coil spring with it installed on truck. Make sure coil pressure is off the control arm. Replace one u bolt at a time. AutoZone rents tools for free with a deposit or just about any parts store.
Posted via Mobile Device |
So I bit the bullet and removed the springs. I have recently done the ball joints so it wasn't too bad. I am becoming an expert in spring removal... lol. Those new LCA u bolts are way beefier. It appears that at some point one of the u bolts had been replaced (pass rear) with the larger ones. The remaining three were the originals. Hardest part after the springs were unloaded was reaming the holes away from the cross member a bit to clear the 7/8 nuts on a couple. Stockers were 5/8 nuts. Thanks again guys!
Hey Cantada,
Where'd you get the u-bolts from?
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
Rockauto.com. Dorman part number 13503. Nice and beefy.
Thanks Man!
