Old 06-26-2003, 04:00 AM   #1
chewed 71'er
71-72 Front Brake Calipers...Sticky Pistons?
Has anyone ever experienced stuck or sticking pistons in their brake calipers? From the amount of rust I cleaned out of the bleeder valves, I think the calipers in my 71 are original. In everyday driving, it stops okay. But stopping in a hurry is a problem, as truck wants to continue rolling, and brake pedal seems solid (but not bottomed out). Sometimes rear brakes lock up stopping hard, doesn't pull left or right. Have plenty of lining on front pads and rear shoes. Recently replaced master cylinder and proportioning valve (for leaks), throughly bled all 4 wheels. Power booster is working properly. I guess there's the possibility of worn rotors?
chewed 71'er is offline   Reply With Quote
Old 06-26-2003, 05:14 AM   #2
Lippyp
English Chevy Owner
Lippyp's Avatar
Standard mineral brake fluid is Hygroscopic (this means that it absorbs water) If the fluid has not been changed for a long time the fluid can become waterlogged and this can lead to the boiling point of the fluid reducing leading to increased fade under heavy/prolonged braking and can also attack any iron or steel components in the braking system. This happens more if the vehicle hasn't been used for a while so I would imagine that it is possible that you have rusted calipers.
It's not worth taking risks with brakes so I would consider replacing them. Also check the flexible hoses on the front, it is possible for them to weaken and balloon when you step on the brake so losing pressure to the calipers. You should be able to get any brake shop to check your rotors to see whether they are still in tolerance.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 06-26-2003, 10:05 AM   #3
jerry moss
Born Psycho
jerry moss's Avatar
Lightbulb
hard pedal and still rolls, sounds like a bad booster. also check the caliper slides and make sure everything moves freely.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 06-26-2003, 10:28 AM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Like Jerry said. Check the caliper bolts, chances are they are in pretty sad shape. These are the slides Jerry is referring to.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-26-2003, 10:41 AM   #5
Piston
Piston's Avatar
I would lean more towards low vacuum or leaking booster, both will have the same affect. during slow application the booster is able to assist but in a panic stop it doesnt have the capacity to assist that quickly.
Piston is offline   Reply With Quote
Old 06-26-2003, 10:10 PM   #6
jimfulco
Some brands of pads are just that way. I put Raybestos semi-metallics on my 72 Nova & they fade almost as bad as the OEM pads did. Anything over 70mph is scary. I've used Delco & EIS pads on that car in the past & it would stop so fast from 3-digit speeds that your ears would pop. My daily driver is an 88 Tbird, & it has Albany semi-metallics from Auto Zone & they work quite well, considering the car weighs nearly 4000 lbs. & has the little 10" discs.
jimfulco is offline   Reply With Quote
