Old 05-30-2013, 12:40 PM   #1
JWheeler331
JWheeler331's Avatar
Radiator Question
My radiator got a large hole in it the other day and I am looking at replacing it.
Autozone here sells one that is supposed to be a stock replacement for my truck.
http://www.autozone.com/autozone/par...6849_266534_0_
I got to looking though and found this one on ebay.
http://www.ebay.com/itm/190847686059...torefresh=true
Here is my question though as I dont know too much about the real differences in radiators.
First.....is the second radiator better than the autozone one and will it work in my truck?
The ebay listing says its a direct replacement for my truck also. Its a tad bit cheaper and has free shipping so if it is in fact a better one I may just go with that.
Thank you in advance for any info
JWheeler331 is offline   Reply With Quote
Old 05-30-2013, 04:07 PM   #2
ChuckW
ChuckW's Avatar
Re: Radiator Question
Any good local radiator shop will be able to repair (or re-core) your original....
ChuckW is offline   Reply With Quote
Old 05-30-2013, 04:30 PM   #3
Sharps40
Depends....Autozone, Advance and Orellies all sell very similar radiators for 60-66 C10s but they are the larger V8 size though listed for the I6 as well. That said....if you have the I6 radiator, the larger V8 size for sale as a suitable replacement won't fit w/o the v8 top clamp, V8 lower clamps, V8 rubbers, and v8 hoses (V8s are 1.75" top and bottom outlets while the I6 uses 1.75" lower and 1.5" uppers), also need the V8 airdams/sheet metal.
So, do you have the I6 or V8? If V8 I used the Advance Auto Radiator, internet code P20 usually gets you 20% off and free shipping bringing the delivered to your door price around $190 for a new brass tank, 3 tube V8 radiator that is pretty close in looks to the original Harrison.
As for I6 radiator, I never found one anywhere new.....Ya see, about 66ish they started using the V8 rad on the large 6s and I think that's why you can only get one size these days.
Sharps40 is offline   Reply With Quote
Old 05-30-2013, 05:39 PM   #4
JWheeler331
I have a 283 V8
Old 05-30-2013, 05:57 PM   #5
Sharps40
Okay. The Radiator from Advance auto should be a very close bolt in. The differences I noted were mostly cosmetic. But it has 3 tubes instead of 2. It comes with a trans cooler and you'll have to notch the DS lower mount to clearance for the trans cooler line fitting.
Old 05-30-2013, 06:22 PM   #6
luvbowties
luvbowties's Avatar
Smile Re: Radiator Question
i'VE BOUGHT SEVERAL ALUMINUM ONES FROM eBAY--BEGAN WITH a personal, CHEAP, 3-ROW, AND cosmetic QUALITY WAS LACKING, yet cooled adequately and fit was ok. Had a chance, sold it, & replaced MINE with a 2-row Champion, lifetime guarantee, had 2 big cores bigger than the 3 cores of 1st one. Cosmetically, much superior, fit was fine, and performance has been impeccable for 2-3 years.
Read about the advantages of each over the other--seems like the 2-core Champions have the overall advantage. Even price, iirc, was favorable on the 2-row. And it looks so "cool".
Customers have been happy with both--altho' they only saw the one(s) they ordered.
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 05-30-2013, 10:36 PM   #7
JWheeler331
Thanks for the info. I don't know much about radiators. I needed a replacement and liked the looks of the ebay one so I ordered it and will give it a shot. Maybe it will be worth it.
Old 05-31-2013, 05:40 AM   #8
66C06
66C06's Avatar
check out www.entropyrad.com great quality guaranteed fit and efans if you want.
66 SWB Stepside: Project C-O6
06 ZO6 MSM 6spd 562/520rw N/A
06 Caddy CTS The Daily
07 Hayabusa - absolute chaos
66C06 is offline   Reply With Quote
Old 05-31-2013, 06:04 PM   #9
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I have seen some decent all alum rads on ebay for around $160. No fans, no oil coolers, just a rad.
Something like this one.
http://www.ebay.com/itm/Allan-1963-1...4e43eb&vxp=mtr
I was looking at this one from ebay.. YOu may want to contact them about your year of truck.. I talked to these guys when I was shopping around.. They will add anything you need, coolers or fans.
http://www.ebay.com/itm/1960-1962-C1...61003297732%26
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
