![]() ![]() Join Date: Jan 2011
Wood BEd - Offset washer question
I am converting my GMC over to a wood bed. We are almost to the point we can bolt in the final pieces, but I have a question on the offset washers.
How would they have looked from the factory? I'm just not sure on the orientation of the washer as compared to the bolt holes. Which way would the larger side of the washer go? Assuming more 'away' from the strip explaining why the washers were offset to begin with (?) Just wanted to be sure. I have the actual holes drilled and lined up perfectly I just can't figure out how I should do the offset washer recessed hole orientation. Pics maybe ? Btw- I did search, and found several posts but I am just curious how they looked stock. I'll match mine up as closely as possible. Mar-K has a description of it but no pics I can find (yet) Thanks.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) Last edited by CC69Rat; 05-30-2013 at 02:13 PM. |
Re: Wood BEd - Offset washer question
I'm not sure if this will help you, but this is the only pic I have of my stock wood bed. You can see the orientation of the washers closest to the rear of the truck. I'm not sure why they used the offset washers honestly. Hopefully someone will have a better answer for you.
After flipping through my wood bed pictures they all seem to be pointing forward with the offset. Now hopefully someone with a shortbed will add to this as most of my pictures are Longhorns.
Dads Longhorn has some nice, but not complete, pictures on her thread here. http://67-72chevytrucks.com/vboard/s...d.php?t=581716 The bed washers have offset holes to prevent rotation of the carriage bolt during installation. How are you intending to cut the washer recess? My thoughts are a forstner bit, router or end mill.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 05-30-2013 at 03:13 PM. |
Junior Member
I read on some post that the recessed offset washers were to keep the bolts from spinning when the nuts are tightened. Made sense to me.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
