Old 05-30-2013, 06:36 PM   #1
nigilroyboy95
6.2 turbo diesel
thinking about putting a 6.2 turbo diesel in my 65 gmc 4x4 just not sure if i should any thoughts?
gm boy
nigilroyboy95 is offline   Reply With Quote
Old 05-30-2013, 06:42 PM   #2
D_Lawson
D_Lawson's Avatar
Re: 6.2 turbo diesel
I think it would be great! If you are searching for an engine I would suggest a 95, 96, or 97 donor 6.5 Turbo diesel. I have had both and the 6.5 will please you better I believe. They are not too complicated and trucks in these years are fairly cheap in this area. Just a thought, good luck with it.
D_Lawson is offline   Reply With Quote
Old 05-30-2013, 06:45 PM   #3
nigilroyboy95
[QUOTE=D_Lawson;6098994]I think it would be great! If you are searching for an engine I would suggest a 95, 96, or 97 donor 6.5 Turbo diesel. I have had both and the 6.5 will please you better I believe. They are not too complicated and trucks in these years are fairly cheap in this area. Just a thought, good luck with it.[/QUOTE
thanks this guy in my area only wants 600 for the 6.2 and its in great shape
gm boy
Old 05-30-2013, 06:51 PM   #4
D_Lawson
D_Lawson's Avatar
I would go that route then. Good Luck!
Old 05-30-2013, 06:53 PM   #5
Jmorales3181
Jmorales3181's Avatar
Sounds good to me! I'm in!
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 05-30-2013, 07:32 PM   #6
nigilroyboy95
i either want a 572 or the 6.2
gm boy
Old 05-31-2013, 10:14 AM   #7
1963c-10
1963c-10's Avatar
There are a few trucks here w/diesels
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-01-2013, 12:58 PM   #8
nigilroyboy95
should i do a turbo or non turbo diesel
gm boy
Old 06-04-2013, 03:39 PM   #9
HotRodYJ
HotRodYJ's Avatar
I have the 6.5TD in my 94 Dually. Great light duty engine and would be perfect with great mpg. The 6.2 in my opinion would be a waste of time. I'd go 6.5TD.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 06-05-2013, 09:45 PM   #10
TheMacster
You would definitely want a turbo, also even though the newer 6.5 did have better intakes and cooling systems you would want a 93 and older injection pump (DB-2) since its mechanical, the 4911 is the one to look for. The 6.2 typically had a stronger bottom end and over the years all of them (6.2/6.5) had a few different pre chamber designs. They can be reliable and get decent MPG but are in no way a power house without some serious modifications. Also the heads are prone to cracking and they like to spit out cranks from time to time. What are your expectations out of it? I'm just asking because you said its either the 6.2/6.5 or a 572 and those are two very different options.
TheMacster is offline   Reply With Quote
Old 06-06-2013, 10:56 AM   #11
jimmydean
jimmydean's Avatar
I had everything to put a 6.2 non turbo in a '71, but had to toss it all when I moved. It's not a bad swap from what I gathered. I planned to do hydroboost brakes, there is a great write up on a junkyard hydro setup on here somewhere.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-06-2013, 04:29 PM   #12
McMurphy
McMurphy's Avatar
BrewCity and I have both done the hydro boost installs.
So far I dont think either one of us found it to be too terribly complicated, though I am pretty sure his will be up and running sooner than mine. Having said that, he will certainly be able to provide perfomance info sooner than I can.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 06-06-2013, 04:34 PM   #13
nigilroyboy95
i just want something different than the other trucks around here so either a 572 or the 6.2 or 6.5
gm boy
Old 06-06-2013, 04:38 PM   #14
vegadesign
vegadesign's Avatar
Always!!! do a turbo with a diesel otherwise useless
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
