05-30-2013, 07:39 PM | #1 |
Porterbuilt control arms vs ?
Hello everyone, I'm going to be purchasing a few items for my truck and was wondering what everyones input was on porterbuilt control arms vs stock or other brands? I'm already getting the dropmember and was wondering if I should get the control arms with it or if I should put the money somewhere else on the truck. thanks for the input.
05-30-2013, 07:49 PM | #2 |
67-72 parts collector,…
Re: Porterbuilt control arms vs ?
The newest version of the dropmember will require either Porterbuilt or Michigan Metal Works LOWER a-arms.
(EDIT: the Porterbuilt website says stock 73-87 lower control arms will still work. I would verify that with them) Upper a-arms can be PB, MMW, Ridetech, CPP, or stock. I would just get the PB a-arms. They are sold in stock width or a narrowed version. Call Porterbuilt for all your suspension options.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-31-2013 at 06:13 AM. |
05-30-2013, 08:06 PM | #3 |
Thanks Keith, I didnt know that. I also was wondering what would be the best rack to get with the member and arms and does it adapt to the existing colum?
05-30-2013, 08:14 PM | #4 | |
They use 79-93 Mustang racks. I know Nate has mentioned having failures with certain brands of rebuilt racks. I believe they recommend and sell new racks vs used/rebuilt racks. I just don't remember the brand they use. They can answer all your questions.
05-30-2013, 08:24 PM | #5 |
I'll be calling and picking there brain tomarrow then, I see you know all about the disc brake conversion and I read up on it and was wondering if there a better option for the porterbuilt arms for disc brake options or should I just get some spindles and brakes off a 72 at the junk yard to rebuild them like it says? or would it be better to get a dropmember and arms for the same year of the spindles and brakes for that what I'm going to go with?
05-30-2013, 08:42 PM | #6 |
Screw junk yard parts.
These trucks are 40+ years old. Nothing in the junkyard is worth using. If you are considering a Dropmember, to get your truck low,... you will want drop spindles also. Porterbuilt sells McGaughy's dics brake parts also. You better place your Porterbuilt order soon. There is a 6-8 week wait on parts from what I read on here. They are swamped with business. Which is good,...
05-30-2013, 08:50 PM | #7 |
Wow I have more questions then I thot, I'm going to have to write some stuff down before I call them tomarrow. and thanks Keith you have been ever so helpfull.
05-31-2013, 12:31 AM | #8 | |
good info to know....sucks because I've been saving my pennies and planned on using as set of stock plated a arms, looks like if I order a dropmember now I'm stuck spending more on atleast the lowers to? I'm never going to get enough saved up! lol |
05-31-2013, 06:10 AM | #9 |
