Old 05-30-2013, 09:31 PM   #1
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
2006 d-max glow plugs
so my truck threw a code for 2,3,5 glow plug.replaced the plugs and still the same code.i have read a recall for the gp control module.anyone had a similar problem.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 05-30-2013, 11:10 PM   #2
lowridergmc
lowridergmc's Avatar
Re: 2006 d-max glow plugs
did the glow plugs cycle after you installed them.codes wont clear till glow plugs cycle.and did you replace thr correct glow plugs-odd bank is on the right side and even bank is the left side.
lowridergmc is offline   Reply With Quote
Old 05-31-2013, 12:17 AM   #3
CHIZZLER
CHIZZLER's Avatar
replaced glow pugs.pulled negative to batteries.waited 30 minutes then fired.light is still on.tomorrow i will have a obd2 to verify.
61-crew cab D-max
Old 06-02-2013, 11:42 AM   #4
gmclowsierra
Code won't clear with batteries unhooked. Need a scanner. If the glowplugs didn't cycle the code won't clear either. If they do cycle it could take s few key cycles for the light to go off.
gmclowsierra is offline   Reply With Quote
Old 06-02-2013, 05:38 PM   #5
CHIZZLER
CHIZZLER's Avatar
cleared the cel with a scanner.everything good so far.thanks
61-crew cab D-max
