Old 05-30-2013, 09:51 PM   #1
rs74
rs74's Avatar
What is the cab to axle measurement on a RC dually
Is it 56" and a C&C is 60". I am wondering because if I end up buying this 84 K30 then I thought it might be easier and cheaper to just change the rear end and put a dually bed on it. Of coarse now that I think about it the frame rails might be different widths being it is a C&C truck.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 06-02-2013, 01:07 AM   #2
80SPORT
80SPORT's Avatar
Re: What is the cab to axle measurement on a RC dually
Frame rail widths are all the same
Dually pickups with boxes are 56 in cab to axle...and use the wide track Dana 70
Cab and chassis are 60 or 72 inch cab to axle and use 14 bolt corporate rear end
Above only applies to reg cabs...all crew cabs are 56 inch cab to axle
So it is easy to swap rear axles to switch crewcabs from cab/chassis to dually pickup
80SPORT is offline   Reply With Quote
Old 06-02-2013, 07:48 AM   #3
Cab & Chassis are 60" and 84". All pickups with long bed are 56".
Old 06-02-2013, 08:55 AM   #4
80SPORT
80SPORT's Avatar
You are correct....my error
Old 06-02-2013, 09:02 AM   #5
rs74
rs74's Avatar
Sorry, I should have updated since I found out the answer the other day. Although I didn't know about the 84" on C&C. That is probably what my other K30 is. Haven't measured it the whole time I have had it. Guess I am putting a flat bed on it instead of a pickup bed.
Thanks for the replies
Roy
1987 R10 shortie
