Old 05-31-2013, 10:27 AM   #1
bsmith5455
Fuel mileage
Hey all, getting ready to swap my 3/4 setup to 1/2 ton. Have a free 1982 donor truck with 2:73 rear end. I drive my truck 90 miles a day, it has a 350 with 400 turbo. Anyone else running that high of a gear, and if so, what kind of mileage you getting?
bsmith5455 is offline   Reply With Quote
Old 05-31-2013, 10:38 AM   #2
Longhorn 70
Longhorn 70's Avatar
Re: Fuel mileage
You should also indicate tire size. With a 28" tall tire you'll be around 2129 RPM at 65mph. That sounds right in the power band. You may lose a little out of the hole as the gear will be higher which may drop mileage for stop and go.
You can check gear calculations here.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 05-31-2013, 10:46 AM   #3
cdowns
cdowns's Avatar
Re: Fuel mileage
doubt you will see any better milage more than likely worse in the 8-9 mpg range and it sure wont b any fun around town from a stoplight
Old 05-31-2013, 10:51 AM   #4
bsmith5455
Re: Fuel mileage
Tire size will be 29"
Old 05-31-2013, 10:58 AM   #5
Longhorn 70
Re: Fuel mileage
You'll be OK if you do JUST freeway driving. The starts and stops will just kill mileage.
At 65 you'll be around 2055 RPM....GOOD for mileage. Getting there will be not so good. Driving style and load will make big differences.
