![]() Join Date: May 2005
4x4 Crossmember
Not shilling these in anyway...... just a heads up. Not compatible with stock 5.3 compressor, so I am probably not a player......
http://dirtydingo.com/store/pages.php?pID=19&CDpath=0 |
Re: 4x4 Crossmember
Those are sweet, I am have been contemplating a LSx swap for a while.....this could be the first piece!!!! What would you have to do to run a/c???
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio ..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
![]() Join Date: Sep 2005
Re: 4x4 Crossmember
They sell a relocate kit that movez the ac up high
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: 4x4 Crossmember
Wow, a/c relocate kit is more than the engine mounts
![]() Join Date: Jun 2007
Re: 4x4 Crossmember
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Re: 4x4 Crossmember
Had seen those, prob not a much difference structural strength wise. Anyone know who might have use the Pacific Fab one???
#7 | |
Re: 4x4 Crossmember
http://67-72chevytrucks.com/vboard/s...&postcount=122 I had to remove it after the install because the oil pan was too close to the cross member. I removed it and sent it back to have it fixed. I should have just fixed it myself. All they did was hit it with a cutoff wheel and then throw some paint on it. They claim they have never seen the issue I had before. If I had to do it over I am not sure I would have gone with the PF cross member.
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build Last edited by Crash_OK; 06-01-2013 at 01:49 PM. |
Re: 4x4 Crossmember
Here is one member using it without any issues (except his pictures don't load anymore)
Firebirdjones Gunny Davis lifted his 2 inches to clear Another installation that had to be tweaked I made my own so I have no experience with either. I just want to help give everyone options. I don't think any of these swaps will be without some level of fabrication skills. Good luck with your build
Re: 4x4 Crossmember
I wish DIY would do an LS Crossmember, like their stuff but????
In a perfect world I think I would do this: The C channel from the DIY4x4 crossmember with a CPP universal LS Engine mount. I would get the channel undrilled, narrow the CPP mount, drill the C channel for the CPP mount. Then use existing frame holes to mount c channel permanently, if needed drill new frame holes....... http://www.classicperform.com/Store/...cks/4810LS.htm |
Re: 4x4 Crossmember
Good Stuff.. Thealien, when you modified your DIY crossmember, did the distance between the mounts change? I have one of thos and that would probably be my best deal, my K5 is lifted so interference would not be a problem.
Thanks Josh |
Re: 4x4 Crossmember
Ordering something today!!!!
#12 | |
Re: 4x4 Crossmember
I ended up using the C channel, the plates that bolt to the C channel, the engine mounts and brackets. From there I fabbed up some 1/4 wall 1 1/4 inch chrom molly tubing and joined everything together. It was a pain but worked fine for me. Wanting to stay at stock ride height added to my issues. http://67-72chevytrucks.com/vboard/s...d.php?t=375380 Here you can see the template I made
