Old 05-31-2013, 10:08 PM   #1
yellow400ex05
Thumbs down Dead oil pressure gauge after new sending unit installed. 1986 K10 HELP!
alright i bought my 1986 Chevy K10 and the factory oil pressure gauge never worked, and the needle sits past 60psi, as if it were dead. well it had a 2 prong sending unit in it, so i put the CORRECT single prong pressure sensor in the block, and the oil pressure gauge still sits in the same spot maxed out at 60PSI. what else could be wrong with it? i cleaned the plug area up when it was installed. here's what im talking about.
it wont move or operate, its all plugged in correctly.
yellow400ex05 is offline   Reply With Quote
Old 05-31-2013, 11:27 PM   #2
Gigem
Gigem's Avatar
Re: Dead oil pressure gauge after new sending unit installed. 1986 K10 HELP!
Got a link or picture of the sender you installed? Might be the one the sends a signal to the fuel injection instead of oil pressure gauge. Was it small and easy to install? If so, probably wrong. I made this mistake on mine...
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 06-02-2013, 08:36 PM   #3
Axle
Axle's Avatar
Along with the above, the guage sending unit is behind the distributor and is your typical large can sender.
Alex.
Axle is offline   Reply With Quote
Old 06-02-2013, 09:12 PM   #4
hatzie
Moderator
hatzie's Avatar
You may have the wrong sender. You can get senders in various Ω ranges for different gauges.
GM oil pressure senders should be 0Ω=0psi to 90Ω=60psi.
The aftermarket oil pressure gauge on my ATV is backwards 240Ω at 0psi and 33Ω at 40psi.
Ford used several Ω ranges.
VDO likes 10Ω=0psi and 180Ω=150psi.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-03-2013, 04:37 AM   #5
hatzie
Moderator
hatzie's Avatar
If the gauge wire is open (broken) then the gauge will sit at 3:00 like yours. According to the Schematics the engine compartment oil sender wire could be Tan or Blue.
You can pull the oil pressure gauge without removing the instrument cluster bucket.
Set a meter set to continuity buzzer or one of the Ω scales.
The spring clips form a point down triangle. The point is Ground, IGN is toward Driver door, and Sender is toward passenger door.
Check with the meter leads from the sender connector to sender signal spring clip.
