Old 06-01-2013, 12:16 AM   #1
rs72lb
how low in a 72 longbed?
hey, noob from missouri in a 72 needing some advise....ive read the longbed problems with the carrier bearing in these trucks when you lower them..if i lower the rear say,,3 inches..is there gonna be any issues? when is the point to where you need to go to a single driveshaft? any help would be appreciated.. its a 350/350 short tailshaft 1/2 ton..thanks..
rs72lb is offline   Reply With Quote
Old 06-01-2013, 10:04 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: how low in a 72 longbed?
I would go to a single driveshaft over any truck with a carrier bearing.
That will be a REALLY long driveshaft,... especially with a short shaft TH350.
If you have to run a carrier bearing,... the style with a rear "slip yoke" are superior to the original design that came in these truck.
I had a lowered '69 that had a 3" rear drop, 30 years ago.
I believe I shimmed the carrier bearing mount to help with the bad angles.
Look here for pics:
http://67-72chevytrucks.com/vboard/s...d.php?t=432405
http://67-72chevytrucks.com/vboard/s...d.php?p=175011
http://67-72chevytrucks.com/vboard/s...d.php?p=859747
http://67-72chevytrucks.com/vboard/s....php?p=6079161
http://67-72chevytrucks.com/vboard/s....php?p=5586336
http://67-72chevytrucks.com/vboard/s....php?p=1024765
http://67-72chevytrucks.com/vboard/s....php?p=4256375
There are many many more threads.
Search is your friend here,... and with Google.
Welcome to the board.
Keith
Convert to disc brakes.
Old 06-01-2013, 12:15 PM   #3
rs72lb
thanks for the reply..ill check it out
Old 06-06-2013, 07:24 PM   #4
Square_78
Square_78's Avatar
Lowered a lot in the back. This is at least 9" down from stock. Fender lip is at 23.5" I believe. No driveline vibration at all at this height. Longbed. Two piece shaft and stock carrier bearing. Worst case you just raise the whole bearing UP about an inch or so depending on your drop. Just make a spacer block from some box tubing. Easy fix. Cheaper than buying shims.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
