Old 06-01-2013, 12:03 PM   #1
rs74
rs74's Avatar
How hard to replace the multi-function switch?
The wipers on the K30 I just bought is set up on a toggle switch under the dash. The MF lever is broken and needs replaced. Everything else as far as bright switch, turn signal, and cruise seems to work just fine. I have never had to replace one of these so I don't know what all is involved.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 06-01-2013, 05:43 PM   #2
rs74
rs74's Avatar
Re: How hard to replace the multi-function switch?
How does the switch come out. Do I have to tear down the column to get it off.
Roy
1987 R10 shortie
Old 06-01-2013, 05:59 PM   #3
ont_guy_38
ont_guy_38's Avatar
Yes I believe you have to take the wheel off and the plate that's behind the wheel. The switch is held on with one screw and the wires for the switches are fed through the column itself.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 06-02-2013, 12:06 AM   #4
Greenlee
Greenlee's Avatar
The lever itself just pulls straight out if I remember correctly. You have to remove the steering wheel and locking plate. Both are easy to remove with the right tools which are available cheap at Autozone. The hardest part is feeding the wires through the column. I had the column out of the truck and it was still a pain to feed the wires through.
Greenlee is offline   Reply With Quote
Old 06-02-2013, 09:06 AM   #5
rs74
rs74's Avatar
Maybe I can tie a string to the end of the connector before I pull the switch out. That way maybe I can just pull the new wiring back through the column with the string. Not sure if it will work but worth a try. I was hoping I didn't have to pull the steering wheel and plate underneath it. Oh well.
Roy
1987 R10 shortie
Old 06-02-2013, 07:24 PM   #6
MalibuSSwagon
Dozens of articles online on rebuilding a Saginaw steering column
MalibuSSwagon is offline   Reply With Quote
Old 06-02-2013, 08:07 PM   #7
hatzie
Moderator
hatzie's Avatar
That's what I'd do...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
