Old 06-01-2013, 12:46 PM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
trac bar bushings
i called my local napa auto parts store,guy says he cant get them,anyone know where i can find them.
1966FLEETSIDE is offline   Reply With Quote
Old 06-01-2013, 06:08 PM   #2
1966FLEETSIDE
Re: trac bar bushings
thats it thx bud.i think its the guy behind the counter
Old 06-01-2013, 06:16 PM   #3
jayoldschool
Moderator
Are these easy to change? May as well add them to the list when I do the control arms...
jayoldschool is offline   Reply With Quote
Old 06-02-2013, 01:31 AM   #4
Captainfab
60-66 Nut
I see there isn't a price on those. In my experience most of those "Rare Parts" parts are $$$$$
I'm all for buying local, but have you checked with LMC or Classic Parts?
Old 06-02-2013, 09:53 AM   #5
HOTFUN
HOTFUN's Avatar
NAPA online shows $49.99 each on that bushing #. GM still sells them in their original boxes as I bought a pair for my trailing arms on 3/5/13. Group 5.381 part # 3762012 bushing list price then was $21.91 ea. Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 06-03-2013, 12:57 AM   #6
Captainfab
60-66 Nut
Were you able to get them from a local dealer, or was it from one of the online GM parts retailers such as gmpartsdirect?
Old 06-03-2013, 09:12 AM   #7
HOTFUN
HOTFUN's Avatar
Sorry, I may have been mistaken on what bushings on the rear end you are asking about. My reply posting was for the rear trailing arms, front bushings for the coil spring rear end that I posted the part# for and they were available from any local GM dealer. The single factory rear stabilizer link bar was sold as a complete bar with bushings from GM in my GM parts book and was discontinued. I was able to find a NOS bar with bushings for mine for $75. I know the reproduction bars for about $69 are complete and adjustable for length too if your doing any height modifications.
'72 GMC K2500 4x4
Old 06-03-2013, 09:24 AM   #8
cantada
Your other option... If you would like to try poly is energy suspension they may both bushing inserts and the set is less than $20 I think. Just drill out the old bushing, apply the supplied grease and insert. Was very easy and at a great price. You can also do the same for the truck arms, u just have to leave the old bushing outer shell in place.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=518877
cantada is offline   Reply With Quote
Old 06-07-2013, 06:37 AM   #9
luvbowties
luvbowties's Avatar
Smile Re: trac bar bushings
Advance auto parts...
>> http://shop.advanceautoparts.com/web...hedFrom=header <<
*TAKE OLD ONE--OR ENTIRE BAR--TO ENSURE COMPATABILITY--SOME OF THEM FIT--I BO'T MINE THERE.*
**Notice price as compared to $49.99 each!!! I'd avoid their "rare parts"/priced like gold category, tho'.
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 06-07-2013, 10:43 AM   #10
Lugnutz65
Lugnutz65's Avatar
I replaced my trac bar and trailing arm bushings with polyurethane ones I bought from LMC. Here is my method for old bushing removal. Leave the metal bushing there if you use the polyurethane replacments. EASY!!
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-07-2013, 11:06 AM   #11
jayoldschool
Moderator
I know what I'm doing with my new old arms! Thanks!
Old 06-07-2013, 01:23 PM   #12
cortcomp
cortcomp's Avatar
Both the control arm/trailing arm and radius arm bushings are sold for dirt cheap at summit, energy suspension brand no less. The radius/tracking/panhard bar bushings came right out. Couldn't even press out the trailing arm ones without the rubber sucking the pin back in. You re-use the outer shells anyways, and i did this on the truck: Support one arm so rear doesn't rotate down, remove bolts, lower arm down below mounts, or jack up if bed is off (i had no driveshaft to dealw ith.)
Heat INNER metal bushing tube lightly from inside with propaane/mapgas torch, jsut when you start to hear any sizzle, like quiet fast sizzling bacon, stop, and push out easily with screwdriver or punch or whatnot. They literally slide out. With the metal bushing out, when cool in a few minutes, the rubber will come right out. Easiest bushings on the whole truck.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 06-08-2013, 12:57 AM   #13
1966FLEETSIDE
wow thats why i like this site so much,thx lugnuts for the great example.
