Old 06-01-2013, 03:00 PM   #1
SkinnyG
SkinnyG's Avatar
C-Arm ground clearance, 15's and ??? drop?
How low can I drop the front before the lower control arms hang below a 15" rim?
I should have measured before I ripped the front all apart, but hindsight is always 20/20.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 06-01-2013, 05:05 PM   #2
Mikec10
Mikec10's Avatar
Re: C-Arm ground clearance, 15's and ??? drop?
Depends on the whole diameter of the wheel not necessarily just the size of the rim.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 06-01-2013, 09:32 PM   #3
SkinnyG
SkinnyG's Avatar
Ah, right, yes. That makes sense.
Let me try again:
At what amount of drop does the control arm hang lower than the edge of a 15" rim?
Reason I ask, is up here it's is illegal for anything to hang below the rim, and I don't want a fix-it ticket quite yet.
Old 06-01-2013, 09:39 PM   #4
mgchevyparts
mgchevyparts's Avatar
Only drop spindles and lowered lower control arms will lower the control arm, springs don't. How much you going to drop? If you do spindles and springs the control arm will not come close to being lower then the rim.
mgchevyparts is offline   Reply With Quote
Old 06-01-2013, 10:54 PM   #5
mkdesign
mkdesign's Avatar
Also depends on if you are trimming the coils alone or in conjunction with dropped spindles. With my two full coils trimmed ( 3/4 ton coils and 16" rims mind you) I still had descent clearance,but when I installed my 2 1/2" dropped spindles it put my lowerer control arms very close to the ground. My options now are taller tires than my 235/60-15's (nope), bigger rims (maybe 20's), heavier springs (probably) or raise it (no way!) I would probably go with the standard 1 1/2 coils with your 15's to start with.
mkdesign is offline   Reply With Quote
Old 06-01-2013, 11:29 PM   #6
SkinnyG
SkinnyG's Avatar
I have 3" spindles (still in box), and am/was planning on trimming half or one coil off the stock (1/2 ton) springs. Rear is a flip kit on HD leafs.
It's not really ground clearance I'm worries about (despite my poorly worded thread title), it's the hanging below the rim. I'd ~like~ to keep the stock 15" rallys, but I need the front low enough to match the flip kit in the back without hassle from the popo.
I can always buy larger rims..... but I'm trying to keep the truck on a budget.
Old 06-01-2013, 11:29 PM   #7
SkinnyG
SkinnyG's Avatar
Wait. I checked out your truck at LordCo today. And the blue short box across the street.
Old 06-02-2013, 12:00 AM   #8
mgchevyparts
You will be OK with the spindles as far as where the lower A arm is, lowered coils will not effect the lower a arm position. Depending on the rim back space they may not fit the drop spindles, I think 4" BS is max to clear with drop spindles
Old 06-02-2013, 12:03 AM   #9
SkinnyG
SkinnyG's Avatar
The inner pivot won't sit below the rim?
I have read that I may need to trim the control arms to fit stock 15's. I'm ok with that. I short-boxed and notched the frame in the back.
Old 06-02-2013, 12:26 AM   #10
mgchevyparts
Your a arm will be 3" lower to the ground with those spindles, springs will not change that. Springs lower the body only.
Old 06-02-2013, 01:07 AM   #11
wraprail
wraprail's Avatar
He is not asking about ground clearance, his concern is keeping it legal to avoid a ticket.
Most states that I am aware of do not allow any part of a vehicle to hang below the bottom of the wheel/rim. It's for safety
When I was static dropped I had 15" wheels, a 2.5 drop spindle & 3" drop springs and my lower control arms were way below my wheels. Very dangerous in the event of a tire falure.
Then I bolted 20" rims on with no other changes and had mucho clearance.
Tire size makes no difference at all. It is wheel size that makes the difference. (as well as springs and spindles)
wraprail is offline   Reply With Quote
Old 06-02-2013, 01:15 AM   #12
Reziel_1983
Reziel_1983's Avatar
Here's a picture of mine, I think this is what you're looking for. I have 3 inch djm drop spindles and 1 cut coil with 15 inch rims.
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD
1998 Trans am, mostly stock with magnaflow catback
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329
Reziel_1983 is offline   Reply With Quote
Old 06-02-2013, 01:40 AM   #13
SkinnyG
SkinnyG's Avatar
That is exactly what I'm looking for, and it's not looking good.
I've shortened and notched the frame already, which is questionably legal in these here parts. It's not going to help me having control arms arms below the rim.
Guess I better look for bigger rims.
Old 06-02-2013, 02:11 AM   #14
SkinnyG
SkinnyG's Avatar
And this is before the springs were cut?
Old 06-02-2013, 02:46 AM   #15
Reziel_1983
No, that's with only the rear dropped I think. This is with drop spindles but no springs cut. Sorry, I don't have a picture of the front to give a view of the control arms.
Old 06-02-2013, 07:18 PM   #16
SkinnyG
SkinnyG's Avatar
Thank you so much.
Old 06-03-2013, 03:00 AM   #17
INSIDIOUS '86
INSIDIOUS '86's Avatar
Well if you have the time the skill and the patience and if need be money. You could section the crossmember 1.5-2in to lower the truck so that you can gow low without making anything lower than the rim
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-03-2013, 10:33 AM   #18
SkinnyG
SkinnyG's Avatar
I have actually been looking into that. Either Z the frame, or raise/pancake the crossmember. Or a combination of both (to affect the steering less).
Or put on a later plastic deflector to hide it
Old 06-03-2013, 01:19 PM   #19
tony58
I measured a bone stock 76, there is 2.5" between the edge of the 15" wheel and the bottom of the A arm, so a drop spindle will put your A arm on the ground with a 15" wheel(in case of flat tire). Easiest to buy bigger wheels, or use lowering springs only. Use air bags!
tony58 is offline   Reply With Quote
Old 06-03-2013, 01:30 PM   #20
KQQL IT
At the body shop.
KQQL IT's Avatar
Drop member
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is online now   Reply With Quote
Old 06-03-2013, 06:41 PM   #21
SCOTI
SCOTI's Avatar
Bigger diameter wheels & spindles would get my vote for best approach.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
