mechanical oil pressure gauge.
What do I need to do to swap out a mechanical oil pressure gauge for either an electrical one or a different style. I am tire of the mechanical line leaking at the back of the engine block behind the distributor and am looking for another option.
Thanks, Joe 1972 C10 350 Auto |
Re: mechanical oil pressure gauge.
I think you can get a newer style oil pressure sender and run a wire from it to dash. Then find a electrical oil pressure gauge and just run power to it when the ignition is on.
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
what makes you think that your electrical sending unit will not leak just like what you have now??? both screw into the same hole
Carpe manana
![]() ![]() Join Date: Dec 2010
I had a local shop convert a mechanical oil pressure gauge to electric for my K20 build (see link in signature). There's no oil line into the cab just a wire and the OEM look of the gauge is preserved. This conversion can be done using a 60lb mechanical gauge replaced with electrical "innards" for 80 or 100 lb pressure.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Because the one I have now leaks where the metal line goes into the fitting that screws into the block.
I'd replace the line with a new one. Need to make sure you get the correct line kit, not a universal kit with compression ferules. The compression ferules will never seal to the stock fitting in the block.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
![]() Join Date: May 2005
I have always bought a braided fuel pressure guage hose kit, seals good, has the swivel fittings so it does twist, has fit everyone I swapped.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Any hydraulic shop will sell you a new copper line with the proper end fittings for well under 10 bucks. That should hold you for another 40 years of leak free use.
I see autometer makes a braided steel line that comes with fittings. any idea if I need a 3,4 or 6 ft line?
Napa gave me the ends for free. I reused the original line.
Never even thought about converting to an electric gauge... im subscribed
#13 |
replied to wrong thread. sorry. too many tabs open
#14 |
Do you have the compression fitting type? I much prefer the flare type fitting. If not already, you should have a few loops in the hard line between block and firewall to absorb vibration & movement.
#15 |
Just replaced my old plastic leaky line with this. Works perfectly...http://shop.advanceautoparts.com/p/b...584/10717221-P
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
#16 |
#17 | |
Posted via Mobile Device |
#18 |
![]() Join Date: Jul 2016
I'm converting my ammeter (battery gauge) to voltmeter and was considering replacing mechanical oil pressure gauge to electrical too. See my thread, http://67-72chevytrucks.com/vboard/s...=747394&page=3
http://www.classicinstruments.com/ can hook you up with the switch-over if that is what you want. ![]() |
#19 |
I converted my Oil Pressure gauge to electrical using a mid 80s gauge and sending unit.
I had to modify the instrument cluster backing plate and the gauge mounting bracket to make it fit. I also do not have the original wiring harness, I have a Painless Wiring harness which already includes an electrical oil pressure circuit. The only thing I had to do was figure out which connection on the back of the gauge was hot, and which one was ground. The sending unit is much larger than most so it required a 45 degree fitting so it would miss the HEI distributor. I think it turned out pretty well. |
#20 |
Looks GREAT! Got any pictures of the back?
I'm installing a complete American Auto Wire (AAW) Upgrade in my truck now, so NOW is the time to make this all good. DJ Last edited by DJ_Baar; 06-06-2018 at 03:48 PM. Reason: Forgot something. |
#21 | |
Carpe manana
#22 | |
#23 | |
#24 |
Here's a link to the style gauge I used.....
https://www.ebay.com/itm/vintage-NOS...sAAOSwBSxbGENf The sender is from the same year models. I think I bought it through rockauto.com. You just need to make sure if you use a 60 PSI gauge to get the 60 PSI sender. Same for the 80 PSI gauge, use a 80 PSI sender. No, unfortunately I do not have any pics. The install was pretty simple. I used a dremel tool to cut away some of the metal out of the back side of the cluster. I seem to remember I had to bend the edge to the gauge face back to make it fit. Also, I think the gauge is only held in place by the one screw on the face of the gauge. It was not a real "pretty" job from the backside of the cluster. |
#25 |
Check-out this link I got from Cliff at CLASSIC Instruments.
http://shop.classicinstruments.com/other-2-18-gauges-5 Have not tried yet and asked Cliff a couple questions about how to make these work. |
