Old 06-01-2013, 08:45 PM   #1
slammed427
slammed427's Avatar
Droppin the 74
Well I finally got off my rear end and dropped the 74. I've had most of the parts sitting around since March or so. I did the bulk of the rear end drop by myself last night and buttoned it up this morning.
The flip saddles I got from Specialty Retail here on the site, worked like a charm.
The rear end back on the ground.
This morning I got started on the front end. Due to a leaking brake hose and steering box, it took FOREVER to get the spindle apart. Once it was though, It went quick... Until Arizona summer got the better of me.
I've been on break for a few hours now, drank some gatorade and water and am about to go hit it back up. I should have some more pics tonight or in the morning.
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 06-02-2013, 12:27 AM   #2
Houses
Re: Droppin the 74
thats a nice drop! sic wheels too! cant wait to see the front dropped. have any before pics?
Houses is offline   Reply With Quote
Old 06-02-2013, 06:22 AM   #3
wraprail
wraprail's Avatar
Re: Droppin the 74
You may need a shorter rear shock or shock extenders.
wraprail is offline   Reply With Quote
Old 06-02-2013, 07:47 AM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
Re: Droppin the 74
very nice, did you remove leafs to get under axle?
ya the heat here in Houston getting bad too, I work on mine till lunch then take break and back to work around 5pm lol
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 06-02-2013, 12:23 PM   #5
fapfap72
fapfap72's Avatar
Re: Droppin the 74
I like the 74, that green & white are perfect.. I'd like to get my 72 closer to the ground, good luck on the rest of the drop, & beating the heat.. #teamlongbed
72 lwb rat, 305/400, pb, ps, tilt
Build Thread
"I'm gunna be honest I don't know anything about tracking chickens, I just did it for the free liquor. But I'm tellin ya I heard that chicken"
fapfap72 is offline   Reply With Quote
Old 06-04-2013, 07:38 PM   #6
slammed427
slammed427's Avatar
Re: Droppin the 74
Thanks Guys! I am definitely needing the shock extenders, and some frame work as my steering box shredded the frame around the bolt holes. I also need to do the lower ball joints, but its dropped, all leaf springs intact. I need to get rid of the inner fenders as well, but all said and done, it came out nice.
Instagram: mmmdropp
Old 06-04-2013, 07:44 PM   #7
slammed427
slammed427's Avatar
Re: Droppin the 74
And the requested before shot!
Instagram: mmmdropp
Old 06-04-2013, 08:16 PM   #8
Houses
Re: Droppin the 74
much better after the drop. looks really good! what did you use to drop the front?
Old 06-04-2013, 10:16 PM   #9
ivorton74
ivorton74's Avatar
Re: Droppin the 74
I think I want wheels like that on mine. what wheels are those and what size?
ivorton74 is offline   Reply With Quote
Old 06-04-2013, 10:58 PM   #10
slammed427
slammed427's Avatar
Re: Droppin the 74
Its dropped with spindles 2.5"-3" and 1 cut coil.
The wheels are dodge 20" steel spares. I'm running 1.5" adapters on all 4 corners.
Instagram: mmmdropp
Old 06-04-2013, 11:09 PM   #11
mgchevyparts
mgchevyparts's Avatar
Re: Droppin the 74
With spindles and 1 cut coil, the tire isn't hitting the inner fender, is it?
mgchevyparts is offline   Reply With Quote
Old 06-04-2013, 11:39 PM   #12
slammed427
slammed427's Avatar
Re: Droppin the 74
Not unless I hit a pothole.
Instagram: mmmdropp
Old 06-04-2013, 11:42 PM   #13
mgchevyparts
Re: Droppin the 74
Why did you say you have to remove the inner fenders?
Old 06-05-2013, 12:47 AM   #14
ivorton74
ivorton74's Avatar
Re: Droppin the 74
one more question about the wheels...how did u get the chevy center hubcaps to work?
Old 06-05-2013, 12:52 AM   #15
Jewbacca
Jewbacca's Avatar
Re: Droppin the 74
Looks great.
Jewbacca is offline   Reply With Quote
Old 06-05-2013, 12:53 AM   #16
Jewbacca
Jewbacca's Avatar
Re: Droppin the 74
You oval out the holes.
Old 06-05-2013, 11:28 AM   #17
walkerb
walkerb's Avatar
Re: Droppin the 74
1.5 spacers and the rims just bolt on? No other work required? SWEET
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 06-05-2013, 08:47 PM   #18
slammed427
slammed427's Avatar
Re: Droppin the 74
Az Roads suck! There are a lot of potholes around here.
Walkerb, the spacers are actually adapters, sorry if I misspoke. They are 5x5 to 5x5.5 adapters, pretty easy to find. The only thing about them is you need to pull the wheels every couple months and make sure they are still tight. Better safe than getting passed up by one of your wheels on the highway.
Instagram: mmmdropp
Old 06-17-2013, 03:44 PM   #19
slammed427
slammed427's Avatar
Re: Droppin the 74
Incidentally, with my 245/45/20's now that the suspension has settled fully, the tires rub when I turn. Imma try and roll the fender lips, and hope it clears
Instagram: mmmdropp
Old 06-23-2013, 12:38 AM   #20
19666Trucker
19666Trucker's Avatar
Re: Droppin the 74
that is nice truck cant wait to see around town
19666Trucker is offline   Reply With Quote
Old 08-25-2013, 09:42 AM   #21
slimneverdies
slimneverdies's Avatar
Re: Droppin the 74
I need a favor... Can you measure how much space you have in the rear between the tire and the outside bed lip? Do you think with your setup you could have used larger (wider) adapters
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 11-14-2013, 11:54 PM   #22
slammed427
slammed427's Avatar
Re: Droppin the 74
Sorry for the long delay, I've been taking a break from the forums. I'll measure it up in the morning, but there's only about an inch or so clearance in the rear, but I'm also running 275/40/20's back there now.
Instagram: mmmdropp
Old 11-15-2013, 05:08 PM   #23
terrylgreenjr
Re: Droppin the 74
If you are still having a issue with the front tires rubbing the fenders, I did the same thing with the dodge wheels but I bought new rotors and redrilled then to the dodge pattern and have plenty of room on the fender lip side now
terrylgreenjr is offline   Reply With Quote
Old 11-15-2013, 06:51 PM   #24
slimneverdies
Re: Droppin the 74
No problem. I have them setup on the truck already and I might need a bigger tire too. I have a 245/35-20 and 2" adapters which leaves to much space for my taste
Long live SLIM
Old 11-20-2013, 04:24 PM   #25
slammed427
slammed427's Avatar
Re: Droppin the 74
Did you drill them yourself? Any tips? I want to redrill mine, but I can't find a machine shop that will do it.
Instagram: mmmdropp
