Old 06-02-2013, 01:04 AM   #1
dpruim
dpruim's Avatar
A/C wire question
The PO of my truck disconected the ac compressor removing the belt and removing the control wire from the connector at the compressor. Where would this wire come through the firewall and what color should it be? I've searched all the wiring diagrams I could find for this truck but none of them show the A/C control wiring.
76 Sierra w/ 350/TH350
dpruim is offline   Reply With Quote
Old 06-02-2013, 02:12 AM   #2
jon75
jon75's Avatar
Re: A/C wire question
Let me know if you need a more detailed view. I got this from my '75 wiring manual, should be pretty much the same.
1975 GMC Sierra Grande K25HD 350-4BBL 4sp LWB
2009 Infiniti G37S Sedan w/Stillen sway bar kit & K&N Typhoon dual snorkel intakes
ASE certified for brakes, electrical diagnostics and heating and A/C & EPA certified in R12 and R134a
jon75 is offline   Reply With Quote
Old 06-02-2013, 02:45 AM   #3
wraprail
wraprail's Avatar
Dark green. Would be in the a/c wiring harness with a single wire plug close to the firewall. Then a single wire to the compressor with a connector at compressor with a short black wire to ground.
wraprail is offline   Reply With Quote
Old 06-02-2013, 08:42 AM   #4
dpruim
dpruim's Avatar
Thanks, this is exactly what I needed.
