06-02-2013, 09:11 AM | #1 |
autox question
wasn't sure which forum to put this under, but i know alot of the handling/racing guys hang out here.
Was trying to decide what stall to run in my protouring build(4.8-4l60e) - will be mostly doing autox and some road race stuff, plus the usual cruising. Had decided on a 3000 rpm stall, but the more i thought about it the more i wondered how it would effect getting back on the throttle after the apex. Any insight or suggestions would be appreciated.
Trent 12 Cadillac CTS-V 07 Sierra HD 4x4 Duramax 66 C10 Short Wide 63 Chevy II(nova) |
06-02-2013, 01:30 PM | #2 |
Re: autox question
To much stall coming out of corners can be a shock to the tires as you slam the throttle. Especially if just off idle coming out.
A cheap option is a Trailblazer I6 converter. It stalls around 2400 with a 4.8, and they can be had cheap. I got my for $150 when I had my 07. This way you can test stall cheap enough, and it does provide a good kick in the pants from idle. BTW what are you putting this engine into? |
06-02-2013, 02:25 PM | #3 | |
Re: autox question
