Old 06-02-2013, 10:57 AM   #1
BigRed76
BigRed76's Avatar
Why longer track bar?
I just lowered my '71 yesterday, 3" front and 4" rear. I ordered a kit from CPP that included an adjustable track bar, which I liked until I went to install it. This new adjustable track bar is 2" longer than my factory one, and with the 4" rear drop I need a track bar that is 1/2"-1" shorter. Why would anyone ever even make a longer track bar if it needs to be shorter with a drop?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-02-2013, 12:23 PM   #2
chiefcfd
chiefcfd's Avatar
Re: Why longer track bar?
Did it come with a relocating bracket. They had different lengths for bagged trucks. I think they connect at a different location from stock to avoid interference. I have one that is stock length that is adjustable. Fit the stock locations. Maybe you have a different one.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 06-02-2013, 01:49 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
I installed a ccp kit with the bar you mentioned. Mine fit fine. It was screwed all the way in on both ends. It has left hand threads on one end so it can be adjusted on the truck without having to disconnect one end? Was the cpp bar adjustable and unscrewed all the way out when you got it? Not sure whether mine ended up shorter or longer after the install as i just loosely put the frame end on and adjusted the length til it would go on the rear axle stud.
WIDESIDE72 is offline   Reply With Quote
Old 06-02-2013, 01:51 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
Mine did not come with a relocator bracket for the bar, only relocators for shocks
Old 06-02-2013, 02:00 PM   #5
LONGHAIR
You do realize that the adjustability is there to center the axle under the truck? It may not just sit there naturally when disconnected, so you may have to push or pull it one way or the other.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-02-2013, 02:26 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
I checked this after installing and it was even side to side. I assume the shocks kept it even while i was working on it. (?))
Old 06-02-2013, 02:32 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
There are two different adjustable track bars.
One connects at the stock location.
The other is longer and connects to a new bracket installed on the passenger side trailing arm.
Keith
Convert to disc brakes.
Old 06-03-2013, 04:41 AM   #8
Square_78
Square_78's Avatar
How tight should you do up the bolts on either end. My mechanic put mine in and I'm pretty sure he used an impact because I have a feeling it's binding up. I have the cpp deluxe track bar with relocating bracket on trailing arm. There were no instructions but I assume it should just be tightened with a socket wrench and not an impact to like 300ftlbs. Haha.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 06-03-2013, 06:27 AM   #9
cdowns
cdowns's Avatar
to answer the question "why a longer track bar"
a longer track bar cause less side to side movement when using adjustable ride height feature like airbags
Old 06-03-2013, 08:25 AM   #10
BigRed76
BigRed76's Avatar
Thanks for answering my question. I guess I'll have to call CPP today and see what they expect me to do with a longer track bar that came with no brackets.
Zach
