Old 06-02-2013, 11:23 AM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
rear main seal
ive been putting it off,but the increase of oil prices just keep rising.is changing the rear main seal that difficult to replace??it seems like its getting worst.help!!
1966FLEETSIDE is offline   Reply With Quote
Old 06-02-2013, 01:44 PM   #2
FetchMeAPepsi
FetchMeAPepsi's Avatar
Re: rear main seal
Engine type?
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 06-02-2013, 03:03 PM   #3
64shortbox
64shortbox's Avatar
Re: rear main seal
Not that bad actually. I just did mine BUT the motor was out of the truck. To do it in the truck you'll need to drop the flywheel inspection plate, starter, oil pan, oil pump and rear main cap. With the rear main cap off use a small (skinny) flat blade screwdriver and push the upper part of the seal out. Once the upper part of the seal starts to move it rolls right out, I was able to grab it with my fingers and pull it the rest of the way out.
The new seal will push right in. Make sure you offset the seal 3/8" from the bearing cap. Add a small amount of RTV to the ends of the seal ends and a dab on the main cap by the seal ends and put it all back together.
64shortbox is offline   Reply With Quote
Old 06-02-2013, 03:05 PM   #4
64shortbox
64shortbox's Avatar
Re: rear main seal
OOPS, after seeing FetchMeaPepsi's post, my seal install was on a first generation 350
Old 06-03-2013, 12:44 AM   #5
1966FLEETSIDE
Re: rear main seal
fetchmeapepsi its the original 327,,,,,shortbox thx for the info though,it might be the same setup???
