EZ wiring steering column
Need diagram for gm steering column .I have the EZ wiring universal wiring. and after market steering column. 58 chevy stepside. wiring is not going well I'm having problems with turn signals, no power.
Re: EZ wiring steering column
http://stores.homestead.com/ez2wire/...turnsignal_faq
not sure it this works for you, if not google or bing ez wire and tell you how to wire a gm column.
http://67-72chevytrucks.com/vboard/s...d.php?t=475162 |
ezwire uses gm wiring as do most aftermarket columns
i used ezwire, it should be a matter of using the pre-terminated ends into the plug so i imagine your problem is the 2 hots feeding your column the pur wire should feed 12v+ to your multifunction switch (turn switch) the white wire feeds 12v+ from the brakes when the pedal is down i'd test those first, make sure your flasher is in ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Here is a diagram I made comparing the GM wiring connector to EZ wire. Note it is for an Eldorado column which as some extra connections. I found the ez wire plugged right in for both plugs.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
