Old 06-02-2013, 02:21 PM   #1
Houses
Sway Bar Bushing Clamps
does anyone know where i might be able to find these locally? or will i have to get them online?
Houses is offline   Reply With Quote
Old 06-02-2013, 02:27 PM   #2
SCOTI
SCOTI's Avatar
Re: Sway Bar Bushing Clamps
Aftermarket bushings come w/the brackets. Prob won't find many left on dealership shelves but salvage yards usually have them.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-02-2013, 06:54 PM   #3
izzy_Britton
izzy_Britton's Avatar
The two on the right look like conduit clamps? but yeah a wrecking yard should have them.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 06-03-2013, 07:01 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That picture is one of mine. The part number written on the cardboard is still a viable GM number. My dealership keeps them in stock. Just walk in and tell them how many you want.
Old 06-04-2013, 08:09 PM   #5
Houses
Hey TX Firefighter! it is your picture from you how to install sway bar thread. good write up btw helps out alot.
i did get sway at junk yard but wasnt able to get two clamps. think i might just go back and get clamps at the yard cuz the closest dealer with them in stock is further than the yard.
thanks for the replies guys.
Old 06-05-2013, 08:28 AM   #6
SCOTI
SCOTI's Avatar
Or.... Use aftermarket poly units @ the frame rails & the factory clamps w/replacement (parts store/Moog) bushings @ the a-arms. Improve the performance/benefits of having the bar. Energy suspension makes the poly bushings w/brackets in various sizes for <$30.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-05-2013, 01:07 PM   #7
Houses
How does that improve it? I read it somewhere else but I don't get how it works. Is it something you can't explain and just know it works?
Old 06-05-2013, 01:35 PM   #8
SCOTI
SCOTI's Avatar
OE rubber bushings have a lot of excess material which allows movement/flex from deflection. Poly bushings deflect much less. When used in the frame position they allow the sway bar to pivot up/down w/o deflecting. Think of it like a 35 series Z rated tire on a Vette to a 75 series tire on a van. Shorter, stiffer rubber offers better (more precise) control of what ever it contains. Using the OE brackets w/aftermarket (parts store) bushings @ the control arms offer better control vs factory rubber w/o the binding associated when using poly in this position.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-07-2013, 12:39 AM   #9
Houses
Thanks for explaining that for me. Maybe later I will I already had bushings.
I ended up going back to the junk yard for the brackets ha ha ha thanks guys.
