Changing gear ratio
I'm thinking to change my trucks gear ratio to something more mpg-friendly (about 8 dollars/gallon here in Finland).
Because my truck is dually, I thought that it have 14 lug differential cover. After checking it result was that my truck have 10 bolt 7,5/7,625 rear. But as I looked different gear ratios from Ebay, every 7,5/7,625 gear ratios said that it was used in Camaro, S-10 etc. So, does square body duallies have that kind of rear end or have someone changed it? Also, is 3.42 gear ratio with th700 good? Or should it be 3.73? |
| Bookmarks |
