Ole' GMC 450 Vin Decode
I stumbled across an old GMC 450 with a 302 in it. The owner says it is a '54, but it has a 2 piece front window. The vin is 454 30 10600. There might be something like an "F" or "E" in front, but I can't tell. Is it a '54 or could it be a '52/'53?
Hollister Road Co.
Re: Ole' GMC 450 Vin Decode
GMC back then didn't use model years they used model production runs so it could be a split window 54. The numbers look right for it for 52/53 the numbers are right if it has a Z at the beginning of the 10600 then its most likely a 54.
I see 454 30 10600 as a 1953 450 179" wb w/302 if it was 454 30 Z10600 then its a 54 |
There is definitely no "Z".
Could be a early 54 that GM used up some 53 cabs on. Truck users would not have cared and if they complained the dealer probably gave them a chicken dinner as compensation. Also some states required titling based on the year the truck was sold at the dealer not year of production.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
So really there is no way to tell, nobody cared, so I shouldn't either?
Since no one has mentioned it, I wonder if any of you would like pictures...... |
#6 | |
Hollister Road Co.
This is absolutely possible as GMC was not year centered as Chevy was. |
Hollister Road Co.
As you can see, it must of had one too many of something on the roof. |
It's not uncommon for the heavy truck division to lag behind the light trucks when it comes to changes. One example is the introduction of the new C/K line in '88. The heavy trucks kept the old style cabs until 92-ish.
