Old 06-26-2003, 02:18 PM   #1
Myride67c10
Differences 67 & 69
What all differences are there between a 67 and a 69? I’m looking at buying a 69 from a used car dealer and I think this truck has been pieced together. I currently have a 67.
1967 C-10 Use to be Riptide
Myride67c10 is offline   Reply With Quote
Old 06-26-2003, 02:23 PM   #2
nightmare
nightmare's Avatar
grille, hood, front fenders, core support, parking brake, back window. i'm not sure of everything else, but that is a quick list
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 06-26-2003, 04:24 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Aren't they all?
Seriously, if you could list anythig you think is suspect then someone could possibly give you some insight about it. There are some big diffs between 67 and all years, but the diffs are more subtle between 68-72
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-27-2003, 01:22 PM   #4
Myride67c10
Well thanks for the info. One question I do have though is the VIN plate in the same place? This one does not have one that I can find but it is an AC cab and a 69 if that matters.
Old 06-27-2003, 01:26 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
VIN Plate should be on door pillar on driver's side. This will hold true regardless of year
Old 06-27-2003, 01:31 PM   #6
Myride67c10
Thats what I thought I have a feeling somthings up with this truck.
