Old 06-02-2013, 08:53 PM   #1
Southern Shaker
Which POR15 is right for my frame ?
I see all these kits an such for POR15 and i want to do my entire frame so what "kit" do i need to get or do i just need to order everything seperate ?
Southern Shaker is offline   Reply With Quote
Old 06-03-2013, 03:46 AM   #2
Campbel45
Re: Which POR15 is right for my frame ?
There is a kit on ebay with the metal prep, marine clean, and por15 all in gallon size for $160. Doubt you'll need a gallon but thats what I got just incase I find that I need it for other needs.
Campbel45 is offline   Reply With Quote
Old 06-03-2013, 12:38 PM   #3
Cape Codder
Cape Codder's Avatar
Remember that POR-15 has no UV protection and must be top coated when exposed to sunlight. Also once you have opened the can put a piece of plastic bag over the can before closing or you will not get the top off again. It sticks much better to a lightly rusted or sand blasted surface, it doesn't stick well to smooth or shiny surfaces. Good stuff when correctly used.
Cape Codder is offline   Reply With Quote
Old 06-03-2013, 12:47 PM   #4
Chevyc10572
Chevyc10572's Avatar
This is what I used
Chevyc10572 is offline   Reply With Quote
Old 06-03-2013, 12:48 PM   #5
Chevyc10572
Old 06-03-2013, 03:00 PM   #6
weaintscared
weaintscared's Avatar
Originally Posted by Chevyc10572 View Post
Did you brush it or spray it? looks good
weaintscared is offline   Reply With Quote
Old 06-04-2013, 10:46 AM   #7
Chevyc10572
Brush
Old 06-04-2013, 01:38 PM   #8
volksworld
you have to pay attention to flash times...too dry and the next coat wont bond to the previous one...too wet and you've got a drippy mess...I believe its a moisture cure polyurethane base so temp and humidity affect drying...never sprayed it cause I has afraid i'd have to throw out the gun when I was done...so 2 coats por 15 and 2 coats chassis black can be a 16 hour day,so plan accordingly.
volksworld is offline   Reply With Quote
Old 06-05-2013, 02:39 PM   #9
weaintscared
That's my next step on my truck,,, Got to have a good looking frame
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=468622
Old 06-05-2013, 05:20 PM   #10
54belair
54belair's Avatar
I used por 15 and Ive used chassis coat (silver)----I like the chassis coat better. Por 15 is good but the other sprays better and can be top coated with anything---por 15 cant.
The ad says its self leveling and can be brushed on-----but it never lays really flat if brushed.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 06-05-2013, 08:05 PM   #11
elf w/capital T
Yup, i used chassis black, let fully dry and painted with gloss black
elf w/capital T is offline   Reply With Quote
Old 06-05-2013, 08:10 PM   #12
catch2otwo
any advantage to this compared to powder coating other then cost? Im assuming pc'ing will be a better finish and more durable?
catch2otwo is offline   Reply With Quote
Old 06-05-2013, 10:30 PM   #13
leddzepp
Moderator
leddzepp's Avatar
Powder coating is not as durable as POR 15 or chassis coat. POR can also be topcoated with anything. It either has to be "tacky" and not fully cured, or an etching primer can be used if it is cured.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 06-05-2013, 10:43 PM   #14
jjhare
jjhare's Avatar
I used it on some of my parts and frame and was happy with the results. I do have some advice...no matter how hard you try not to get it on you...you will. Fingernail polish remover (stolen from the wife) took it off. Good luck!!
1972 C10 CST LWB
jjhare is offline   Reply With Quote
Old 06-05-2013, 10:49 PM   #15
Southern Shaker
dont suppose any one can tell me how much ill need to do my whole frame ?
Old 06-05-2013, 10:52 PM   #16
jjhare
jjhare's Avatar
2 quarts should do it. I've done half my frame and some misc. parts and still have part of a quart left.
1972 C10 CST LWB
Old 06-05-2013, 10:54 PM   #17
Southern Shaker
Good deal Thank ya kindley ! did you brush or spray ?
Old 06-05-2013, 10:58 PM   #18
jjhare
jjhare's Avatar
I used foam brushes, just don't use the really cheap ones, get the good quality foam ones.
1972 C10 CST LWB
