Old 06-03-2013, 04:27 PM   #1
duceducenine
duceducenine's Avatar
215 65 16 tires for 70 dually?
would 215 65 16 michelin tires with 1500# rating
be okay for a dually towing a 18' car trailer?
just towing trucks no equipment....
i see these 22's towing cant have much more per #
any info would help!
duceducenine is offline   Reply With Quote
Old 06-06-2013, 06:21 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 215 65 16 tires for 70 dually?
anyone?
Keith
Convert to disc brakes.
Old 06-06-2013, 09:23 AM   #3
SCOTI
SCOTI's Avatar
Anything is possible for short term but personally I wouldn't just because the rating is pretty low.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-06-2013, 08:09 PM   #4
duceducenine
would somewhere in the 1650-1800#
rating be better?
i dont want a blowout.....
but the front tires are shot and
found a set of 6 215 65 16 for $260!
Old 06-07-2013, 08:46 AM   #5
SCOTI
SCOTI's Avatar
My opinion is just that.... But, 27" tire is pretty short for a dually/HD app. Is that the tallest you can go?
At best, that's likely a passenger car tire so the load range is the issue once the 2 tires in the rear start flexing (which they will). The front's would prob survive a normal life around town.
The concern would be extended trips under heat/pressure w/the extra loading. Load range tires for HD apps are about 3K each. At 1500#, that's a big reduction. I wouldn't go less than 30% difference so 2100# @ the minimum. The fronts are not so much the issue. The concern of tire flex in the dual positions under extended heat & loading is what would be on my mind.
Also, most reputable shops won't mount a non-load rated tire on a dually/HD wheel application.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-07-2013, 10:05 AM   #6
duceducenine
thanks scoti thats the info i was looking for!
the tires on the rear now are 215 85 16 @2300#
front are 235 85 16
just wanted a lower profile to bag for when i bag
it its easier to load and unload....
but i will keep looking for a taller tire
with more load range
