Old 06-03-2013, 06:39 PM   #1
merlin3
radiator
i called a local radiator shop and asked for a quality direct replacement radiator for a big block that will bolt right in.we agreed on a aluminum Northern brand,i tried to install it but it is too thick and the note from Northern says it will need custom fabricated brackets.so were can i get a quality radiator that bolts in? i don't want to deal with custom brackets.thanks 72 c10 2wd 509 cu in
merlin3 is offline   Reply With Quote
Old 06-03-2013, 07:00 PM   #2
vidman
vidman's Avatar
Re: radiator
I have a Be-Cool 4 core and all i had to do is use the stock 4 core mounts and notch a little off the support to make it fit. very simple
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 06-03-2013, 07:20 PM   #3
merlin3
Re: radiator
vidman,your mounts are mounted to the left and right tanks on top right? on my Northern there is no way for a mount to go on the side with the filler neck [top],also are there different size mounts for these trucks,3 row 4 row?
Old 06-03-2013, 07:47 PM   #4
Orange67
Orange67's Avatar
Re: radiator
Merlin, I put a 4 core in my 67 that had a 2 core in it. LMC had the correct brackets and bushings and a replacement shroud too. I purchased the radiator from a local parts house and everything bolted right in. The unfortunate thing is, to replace the bottom brackets, I had to remove the core support as my frame was directly below the brackets IIRC they are riveted to the support.
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 06-03-2013, 08:01 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: radiator
I had a 4 core in mine from the factory. I got an aluminum 2 core (with 4 core tanks) off of ebay for about 125 bones. Fit perfect.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-05-2013, 07:59 PM   #6
vidman
vidman's Avatar
Re: radiator
There is 2-3 row mounts and 4 row mounts as well. and yes my 4 row mounts are on the top of the rad support
Old 06-06-2013, 07:16 PM   #7
merlin3
Re: radiator
we called Northern they said other guys are having the same problem with attaching a mount to outlet side of radiator.they are making a new style radiator and sending it to me.got my new upper and lower mounts today they are a'lot wider than what was on the truck,guess i got it figured out, thanks.
